Wanted lots of parts
Looking for genuine BMW parts at discounted prices? Try here!
redchurch
Post Mon Dec 10, 2007 1:10 pm
My poor E30 has got a few problems so i'm looking for the following parts . Its a BMW E30 316i, 1989 1.6L manual
Fuel filler pipe (currently has leak near neck), from the parts info i've
seen i'll need the following (part numbers listed)
FILLER PIP 16111180956
LEADFREE FUEL INSERT 16111180157
RUBBER GROMMET 16111176761
SPACER 16111176708
HOSE 16121180402
HOSE CLAMP 07129952115
HOSE CLAMP 07129952119
HEX BOLT WITH WASHER 07119915047
FILLER CAP WITHOUT LOCK 16116750564
RUBBER SEALING 16111179680
I also need a thermostat, set of front/rear bake pads/discs and the
suspension seems to have sagged on one side but i've been told it's "the
bushes". Do you know what this is?
zimmerbimmer1
BMW Parts Meister
Post Wed Dec 12, 2007 11:10 am
FILLER PIP 16111180956 £132.31
LEADFREE FUEL INSERT 16111180157 £2.57
RUBBER GROMMET 16111176761 £1.49
SPACER 16111176708 £2.48
HOSE 16121180402 £13.32
HOSE CLAMP 07129952115 £0.60
HOSE CLAMP 07129952119 £0.51
HEX BOLT WITH WASHER 07119915047 £0.16
FILLER CAP WITHOUT LOCK 16116750564 £15.85
RUBBER SEALING 16111179680 £3.70
Thermostat £22.25
As you say you require rear discs I pressume you
have ABS??
Frt Discs (vented) £64.01 (pair)
Pads £39.95
Rear Discs £43.43 (pair)
Rear Pads £38.34
Not sure on the bushes unless they mean the
subframe mounts.
