a list
Looking for genuine BMW parts at discounted prices? Try here!
sam325is
Post Sat Nov 10, 2007 2:20 pm
Front and back wheel bearings.
z3mcoupe lsd bush
m3 cab top mounts
subframe bushes trailing arm bushes normal or non eccentric i dont know?
arb u shape rubber mounts and brackets
drop links
wheel bearings and all other bits like the locking nut circlip but not the drive flange
new brake pipe t piece and bolt for the rear
all for a 325 sport 1990
zimmerbimmer1
BMW Parts Meister
Post Mon Nov 12, 2007 11:44 am
Front wheel bearings. £101.10 each
back wheel bearings £45.53 each
z3mcoupe lsd bush £21.34
m3 cab top mounts £33.29 (pair)
subframe bushes £50.94 (pair)
trailing arm bushes normal £25.74 (both sides)
eccentric £32.24 (both sides)
rear arb u shape rubber mounts £5.68 pair
brackets £1.10 pair
Front arb rubber mounts £14.59 pair
Brackets £2.75 pair
drop links Frt £26.38 each
drop links rear £10.32 each
new brake pipe t piece £4.34
sam325is
Post Mon Nov 12, 2007 11:46 am
Did you get my PM?
sam325is
Post Mon Nov 12, 2007 12:25 pm
oh those m3 top mounts need to be for an e46 by the way. also do you know if i need the normal or eccentric trailing arm bushes.
Sam
