Hi i need to order some main and big ends bearings ,
i copied this from tec spection , can u help at all
Hi Im stripping My Eta down and need to order new bearings , does any one have bearing size data handy , i found :-
the crank has Red dots next to the main Bearings , i measured the journals with Dig caliper all at 59.99 to 60.00 mm , is that std or ?
the main shells have 4009 u0 AND 1285 480 on the cap and 0790Ud 1267 271 on the lower shells can ui use these numbers to order new ones ?
the big end hole in the rod with shell removed and caps fitted all measure 48.06 mm is that std or under size .? All big ens caps have * I tried to use text speak but the text speak filter stopped me * on them , and the shells mostly have 1284 843, and 844 and on the other end of the shell is 2491 or 288 , or 2795 , is this relevant to ordering shells , 02 87 poss manufacture date? ?
think Ant said use M52 ones as there a better bearing , thanks Frank 07785 974081 how long would delivery be from order please , as i m of this week to build it back up and fit it hopefully thanks
bearings price
