bonnet foam insulation set - 3 pieces
drivers side underdash cowling - rhd with headlamp level control
headlamp level control system
bonnet and bootlid badge
oh and price for a cambelt kit for 1987 325i
thanks
parts
A1BMW325iSport
BristolBulldog
just to let you know,
you could probably import the aircraft refelctive insulation, for the e30 bonnet for same/ cheaper than genuine? major american bmw parts company does it (bit rusty on names now)
also, what about hid, instead of headlight control? might be cheaper as well?
A1BMW325iSport
thanks but i want all original stuff
zimmerbimmer1
- BMW Parts Meister
Bonnet Foam £28.89A1BMW325iSport wrote:bonnet foam insulation set - 3 pieces
thanks
Driver Side Under Dash Panel £40.69
Headlamp Level System pre 09/87 is NLA
not sure if post 09/87 will fit £97.21
Bonnet Badge £10.63
Boot Badge £10.05
Cambelt £17.24
Tensioner if required £48.61
A1BMW325iSport
cheers for that mate, headlamp level should fit as i've upgraded to the later smiley headlights
