Hi Jon
Hope all of you at Cotswolds had a good Christmas and a happy New Year.
Managed to do some work on the E30 over the holidays and inevitably require more parts...
Car: H255 NHK, 316i LUX M40
Please can I have prices for the following:
Water Hose
11 53 1 715 220 was unavailable last time.
Wondering if hose 11531709052 would fit, as I have upgrade the radiator to the larger 400mm size.
Exhaust
Bracket - 18 21 1 178 296
Bracket Clamp - 18 21 1 712 639
Bolt x2 - 07 11 9 904 116
Washer x2 - 18 21 4 690 192
Nut x2 - 07 12 9 922 705
Bolt - 07 11 9 913 612
Bolt x2 - 07 11 9 903 039
Rear Bracket - Subframe - 18 21 1 177 828. Is this the bracket that mounts onto the rear subframe?
Rear Bracket - Bolt - 07 11 9 904 279
Subframe
Knurled Bolt x2 - 51 71 8 181 460
Washer x2 - 33 33 1 127 496
Nut x2 - 33 33 1 126 136
Distibution Block - 34 34 1 111 435
Brake Line Clip Type 1 x2 - 34 32 6 855 500
Brake Line Clip Type 2 x2 - 34 32 1 158 467
Handbrake Metal Clip x2 - 34 41 1 153 126
Handbrake Plastic Clip x2 - 34 41 1 155 053
Rear Trailing Arm Bolts x4 - 33 32 1 136 406
Rear Trailing Arm Nuts x4 - 07 12 9 900 047
Trailing Arm Plug x2 - On the trailing arms there are plastic plugs in the back side. I can't seem to find the part number for these. Please see if you can find these for me.
Rear Brakes
Wheel Bearing Circlip x2 - 33 41 1 128 346. Please check this is the correct one for my E30. There appear to be 2 sizes.
Plastic Plug x4 - 34 21 1 153 890
Dust Cap x 4 - 34 11 1 153 198
Bolt x4 - 07 11 9 913 442
Spring Washer x4 - 07 11 9 933 082
Piston Gasket x2 - 34 21 1 154 783
Front ARB
Bushing x2 - 31 35 1 127 414
Bushing Holder x2 - 31 35 1 127 202
Nut x2 - 07 11 9 905 515
Clutch
Spring Clip - 21 51 1 204 327
Differential
Semi Circle x5 - 33 20 7 572 717
Many thanks
Harry
Winter Maintenance Continues...
TurtleDesignTech
Cotswoldbmw
Hello HArry
I have emailed the prices to you directly by email.
Regards
Jon
Regards
Jon
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
