Bulk parts buy - Price please,
Looking for genuine BMW parts at discounted prices? Try here!
bmw9818
Post Fri Mar 14, 2014 1:56 pm
So from the top.. :)
BODYWORK
Front bumper trim pn - 51111945907 / 08 both left and right
Rear bumper trim pn - 51121945926 / 27 / 28 (Left, right and centre)
Splitter( is it just me or has this gone up $30 :squint:)
Pn - 51711968488
GEARBOX SHIFTING
Bearing shift arm - 25111220707
Bolt - 25111221849
Dowel pin - 23411466134
washer - 25111220439
FUEL
Rubber seal - 16111179680 ( which i assume is the bit where you open the filler cap and its broken)
Fuel hoses
16121180399
16121180409
16121180398
GEARBOX
Mounting bushes - 23711133487
Rear shaft seal - 23121205340 23121205342 (not sure which one?)
Selector shaft seal - 23121282394
Shaft seal - 23111228314
HALF SHAFTS
33219067814
33219067815 (Not sure if they are the CV joints?)
Wheel bearings etc
Drive flange - 33411131121
Lock ring - 33411138648
Wheel bearing -33416762317 (If you could confirm these are both sides?)
Brake pipe T piece - 34341111435 (which is the same througout the years?)
PEDALS
Accelerator cable
Bush bearing - 35411119016
Rubber grommet -35411152331
Accelerator cable - 35411154504
Thanks!
Cotswoldbmw
Post Wed Mar 19, 2014 3:06 pm
Hi There
51111945907 / 08 both left and right £40.43 each
51121945926 £57.12
/ 51121945927 £23.86
/ 51121945928 £30.30
Pn - 51711968488 £107.14
Bearing shift arm - 25111220707 £24.04
Bolt - 25111221849 £4.06
Dowel pin - 23411466134 £1.04
washer - 25111220439 £0.50
Rubber seal - 16111179680 NLA
16121180399 £14.45
16121180409 £14.50
16121180398 £10.81
Mounting bushes - 23711133487 £13.74
Rear shaft seal - 23121205340 NLA
23121205342 (not sure which one?) £13.49
Selector shaft seal - 23121282394 £ 10.61
Shaft seal - 23111228314 £31.43
33219067814 £43.12
33219067815 (Not sure if they are the CV joints?) £37.26
Drive flange - 33411131121 £86.58 (THERE IS A SUPPLY ISSUE WITH THIS BMW DO NOT KNOW WHEN THIS THIS WILL BE RESOLVED)
Lock ring - 33411138648 £2.89
Wheel bearing -33416762317 (If you could confirm these are both sides?) £56.70 YES
Brake pipe T piece - 34341111435 (which is the same througout the years?) £5.86
Bush bearing - 35411119016 £0.82
Rubber grommet -35411152331 £1.54
Accelerator cable - 35411154504 £24.73
Prices inc. E30Zone Discount and VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 12164
There is a P&P cost of £1.99 on all orders under £20
Please remember if you require an urgent response drop our
Parts Department an email
partscheltenham@cotswoldgroup.com
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
bmw9818
Post Tue May 06, 2014 8:15 pm
Brett please could you update the list/pn's I have added/ deleted a few I will call tomorrow hopefully and place the order -
51121945926 £57.12
Petrol flap rubber cover - 51711884358
gearbox mounting - 23711175939 (could you confirm quantity is 2 for the price)
Gasket set for oil filter - 11429059338
rear pop out seals -51361904827 both sides
centre wheel badge- 32331117279
could you confirm availability and delivery times, also emailed to the direct address.
