all the parts I need in one order
Looking for genuine BMW parts at discounted prices? Try here!
Jamie8GTi
Post Thu Mar 06, 2014 5:27 pm
31321117376 set of two front strut shock nuts
31211126790 set of two front dust cover caps
31211130125 set of two front hub nut caps
2 x 34321160027 Brake pipe bracket set of 3
3 x 34341163565 Brake Pipe clip set of 2
34321154322 Brake pipe rubber grommet set of 2
34211162061 Left rear brake guard
34211162062 Right rear brake guard
34111154241 protection plate left
34111154242 protection plate right
51481962045 insulating panel left
51481962048 insulating panel right
51481916447 central insulating panel
11221744338 1 m20 single mass flywheel dowel
31331124322 2 lower spring pads
31331128523 2 upper spring pads
33411124945 2 rear hub nut securing plates
33411125664 2 rear collar nuts
also I've had a quote before, for a rubber surround that goes behind the filler cap and around the filler neck.. the cars chassis number is WBAAC12040AA87815 if you could get me a price for one and add it to this invoice i'd be very grateful cheers.
hoping to order this all tomorrow or saturday depending on reply thanks a lot! :)
Jamie8GTi
Post Fri Mar 07, 2014 12:48 pm
and please add these onto the list
33551129195 I'm hoping this is a part number for two rear anti roll bar cups, (the little bracket that houses the bush for the arb)
07119915066 And this should be the part number for two bolts to secure it!
I require just the parts to secure the anti roll bar to the chassis of the car (already have bushes), realoem shows another upper plate which hasn't got a part number on the site (which may mean its not needed) but if its needed please quote for it.
If it makes any difference its for a 12mm Rear anti roll bar off an 89 325i convertible and I'm retro fitting it onto my 1989 316i chassis (along with the 6cyl subframes, trailing arms and brakes.)
cheers guys!
Cotswoldbmw
Post Fri Mar 07, 2014 2:41 pm
Hi There
31321117376 set of two front strut shock nuts £20.35 for 2
31211126790 set of two front dust cover caps £3.26 for 2
31211130125 set of two front hub nut caps £3.78 for 2
2 x 34321160027 Brake pipe bracket set of 3 £1.28 for 2
3 x 34341163565 Brake Pipe clip set of 2 £2.17 for 3
34321154322 Brake pipe rubber grommet set of 2 £5.23 for 2
34211162061 Left rear brake guard £24.04
34211162062 Right rear brake guard £24.04
34111154241 protection plate left £33.28
34111154242 protection plate right £33.28
51481962045 insulating panel left £19.44
51481962048 insulating panel right £22.33
51481916447 central insulating panel £54.00
11221744338 1 m20 single mass flywheel dowel £4.64
31331124322 2 lower spring pads £6.85 for 2
31331128523 2 upper spring pads £9.38 for 2
33411124945 2 rear hub nut securing plates £3.78 for 2
33411125664 2 rear collar nuts £10.46 for 2
rubber surround £19.98
33551129195 £3.24 for 2
07119915066 £1.19 for 2
Prices inc. E30Zone Discount and VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 10801
There is a P&P cost of £1.99 on all orders under £20
Please remember if you require an urgent response drop our
Parts Department an email
partscheltenham@cotswoldgroup.com
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
Jamie8GTi
Post Fri Mar 07, 2014 3:50 pm
ordered cheers :cool:
