E30 rear brakes
Looking for genuine BMW parts at discounted prices? Try here!
Trickye30
Post Fri Feb 14, 2014 8:56 pm
Hi does anybody know if you can use z1 280 mm rear discs and e36 rear callipers on a 4stud e30 ? I know the calliper is the same as the one used on the z1 with the 280 mm discs it is just the carriers ????
senna
Post Fri Feb 14, 2014 9:05 pm
No there are two types of Z1 calipers and disks. The latter (e36) type does not fit as the offset is different
Trickye30
Post Fri Feb 14, 2014 9:09 pm
Can the offset be changed via an adapter plate or machining of the carrier if it is not much or do you know of a calliper that will fit ?
senna
Post Fri Feb 14, 2014 9:13 pm
I am sure it can be done with washers, longer bolts and spacers etc
