I believe every code below where I have written x2 is a code for two of this item.. I only require one of that code in that case.
34211162061 Left rear brake guard
34211162062 Right rear brake guard
34111123072 Disc retaining bolt x2
34211153199 Rear caliper clip x2
34111153197 Bleed valve x2
34111153198 Dust cap x2
34211153194 Caliper repair kit x2
34111157038 Guide bush repair kit x2
34419064266 Hand brake spring repair kit.. I need this for both of the discs
cheers
few e30 bits
Jamie8GTi
and..
63121364431 cable clamps
34111154241 protection plate left
34111154242 protection plate right
34111123072 inner hex bolt
34111154440 front repair kit calliper
34111161936 front repair kit bush
51481962045 insulating panel left
51481962048 insulating panel right
and also been desperately searching for the part number to the rubber surround that goes behind the filler cap and around the filler neck.. the cars chassis number is WBAAC12040AA87815 if you could get me a price for one i'd be very grateful cheers.
Jamie8GTi
And also!! a dowel pin for a single mass m20 flywheel..
I think this is the right code
11221744338
11221744338
Cotswoldbmw
34211162061 Left rear brake guard £24.04
34211162062 Right rear brake guard £24.04
34111123072 Disc retaining bolt x2 £1.28 for 2
34211153199 Rear caliper clip x2 £7.76 for 2
34111153197 Bleed valve x2 £11.00 for 2
34111153198 Dust cap x2 £8.74 for 2
34211153194 Caliper repair kit x2 £37.87 for 2
34111157038 Guide bush repair kit x2 £35.10 for 2
34419064266 Hand brake spring repair kit £28.21
63121364431 cable clamps £2.90
34111154241 protection plate left £33.28
34111154242 protection plate right £33.28
34111123072 inner hex bolt £0.65
34111154440 front repair kit calliper £18.94
34111161936 front repair kit bush £24.73
51481962045 insulating panel left £19.44
51481962048 insulating panel right £22.33
rubber surround that goes behind the filler cap £19.98
11221744338 £4.64
Prices inc. E30Zone Discount and VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 60142
There is a P&P cost of £1.99 on all orders under £20
Please remember if you require an urgent response drop our
Parts Department an email
partscheltenham@cotswoldgroup.com
Brett
11221744338 £4.64
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
