13417831480 ICV pipe.
34302229632 Servo vacuum pipe.
11127833733 Head gasket 1-4.
11127833734 Head gasket 5-8.
13541406352 Throttle body O-rings x8.
11121406247 Water rail O-rings x6.
11531406249 Thermostat O-rings x4 (larger).
11531407002 Thermostat O-ring x2 (smaller).
11531312287 Thermostat bottom seal.
13641730767 Injector O-rings top & bottom x16.
11349063193 Valve stem oil seals x16.
11127583115 Head bolts x20.
11140001186 Upper timing case gaskets. x2 (Listed as 2 required. Do I need 2 or 4 for both timing cases?)
11137831014 Sump gasket upper.
11131407532 Sump gasket lower.
07119963151 Drain plug washer/gasket.
11241405890 Big end bolts x16.
13621709966 E30 water temp sender.
13621725323 540i inlet temp sender.
Cheers! Dave.
