Hey. Quite a list but could I get price and avaliability on the following please?
11811129286 - Rubber engine mounting - 2 please, one for each side
11131727974 - Upper sump gasket
11131727983 - Oil pan gasket
11141727986 - Timing chain gasket set
11121734276 - Rocker cover gasket
11421312607 - Oil filter housing gasket
11611734435 - Inlet manifold/coolant pipe gasket
11611734436 - Inlet manifold gasket - 3 please, one for each port
25117519669 - Shifting arm bush
25111220707 - Shifting arm bearing
25117501212 - Gearshift Rod joint
25111221243 - O-ring x2
25111220199 - Spacer
07119932863 - Circlip
23411466134 - Dowell pin
25111203682 - Tension bush
25111434194 - Plastic washer
25111220439 - Plastic washer x 2
25117571899 - Securing clip
25111220600 - Shift lever bearing
23711175939 - Gearbox mounts - x2
23121282394 - Selector shaft seal
Also, is it possible to order a Z3 1.9 gear shifter off you or do you need a VIN?
Price and avaliability please
Cotswoldbmw
11811129286 - Rubber engine mounting - 2 please, one for each side £73.46 for 2
11131727974 - Upper sump gasket £12.61
11131727983 - Oil pan gasket £10.13
11141727986 - Timing chain gasket set £12.49
11121734276 - Rocker cover gasket £12.73
11421312607 - Oil filter housing gasket £3.96
11611734435 - Inlet manifold/coolant pipe gasket £4.15
11611734436 - Inlet manifold gasket - 3 please, one for each port £3.70 for 3
25117519669 - Shifting arm bush £7.61
25111220707 - Shifting arm bearing £22.68
25117501212 - Gearshift Rod joint £19.55
25111221243 - O-ring x2 £1.72 for 2
25111220199 - Spacer £0.46
07119932863 - Circlip £0.16
23411466134 - Dowell pin £1.04
25111203682 - Tension bush £0.73
25111434194 - Plastic washer £0.96
25111220439 - Plastic washer x 2 £1.54 for 2
25117571899 - Securing clip £0.82
25111220600 - Shift lever bearing £6.94
23711175939 - Gearbox mounts - x2 £41.95 for 2
23121282394 - Selector shaft seal £7.02
PLEASE NOTE AVALIBILITY HAS NOT BEEN CHECKED DUE TO BMW LINK BEING DOWN
Prices inc. E30Zone Discount and VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 59499
There is a P&P cost of £1.99 on all orders under £20
Please remember if you require an urgent response drop our
Parts Department an email
partscheltenham@cotswoldgroup.com
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
