I though I was buying second hand wings to replace the 2 on my touring. so I didn't take the threaded clips (2) each wings that fix inside the door hinge (back of wing) . and I also need the nylon inserts to fix the side trim and indicator's
I have all fixing from the car but need all parts for 2 bare new wings.
Thanks.
bare wing parts..
savagehenry
Cotswoldbmw
Hi There
the insets for moulding and light are easy enough to find, i am not sure what the threaded clips are you require, maybe have a look at realoem.com section 41 and see if you can confirm which item you need
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
savagehenry
Yes, sorry it's a bit vague, if you lay a wing on the ground lights (front) to your right door end to your left. I have 2 holes in the wing and 2 holes in the inner wing (on car) so there were 2 clips (folded) that push onto the wing that have a thread in them to fix the wing to the body of the car.
Sorry about this, I'm a newbie to BMW's i will try and find a diagram of the fixings.
Thanks.
Sean.
Thanks.
Sean.
savagehenry
The fixings go onto these.
