Price please
Looking for genuine BMW parts at discounted prices? Try here!
kingcruizer
Post Sat Sep 10, 2011 11:24 am
Hi, can I have a price on a full set of main bearings for a m20b25 engine and I would like to install a quick shift but don't know what bits I need so can I have a price for that to.
Many thanks
Clive
"BEFORE I DIE, I WANT TO OWN A CAR WITH AN ENGINE THAT STICKS OUT OF THE BONNET"
Cotswoldbmw
Post Mon Sep 12, 2011 9:07 am
Hi Clive
can i get vehicle details, also the bearings are colour coded depending on size required the only way to know which ones are required is to phisicaly looking at them, having said that once i get details i should be able to price them as i dont expect them to be a different price but wont be able to give you a ref number until you know for sure what size and colour code required
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
kingcruizer
Post Mon Sep 12, 2011 12:48 pm
hi brett. thanks for the reply. i'm building a 2.8 so i just have the crank. its in very good condition so i thought standard mains would be ok. i could be wrong. the only ones i have is what came out of the block i'm using.
what would you suggest?
clive
Cotswoldbmw
Post Tue Sep 13, 2011 9:58 am
Hi Clive
BMW list 3 different standard bearings, now if the crank and block are from different cars i am not sure we will be able to get this correct and you might need a local engineering firm to help you out, if the are from same car then this would be a bit easier but i still need chassis number and colour code which will be marked on old bearings yellow, green of white there might even be a part number which might help, i am sorry if this sounds a bit long winded but i want to make sure you get it right, i wouldnt want you putting in the wrong ones building it up and then find it knocks and you have to start again, best make sure we get it right first time
Brett
Cotswold BMW Parts
01242 335365
