Cylinder Head Parts
11121726478
Set Bolt Cylinder Head TORX 1
Complete Headgasket set for 1986 325I X 1.
11311713361 x 1 Timing Belt
11421265376 x 1 Pipe
11351280551 x 1 Guide
52101817063 x 2 COUNTERSUNK HEAD SCREW
BOTTOM END PARTS
11151714390 X2 O RING
07119915031 X4 Hex bolt with washer
11141275466 X 1 SHAFT SEAL
11121285609 X 1 SHAFT SEAL
11141720903 X 1 GASKET
11131730234 X 1 GASKET
11111285403 X 1 O RING
11241713342 x 12 Piston Rod Bolts
11221717840 x 8 Flywheel Hex bolt
11251713195 x 6
REPAIR KIT PISTON RINGS 84,480MM(+0,50)
Also need a set of Main Bearing Bolts, which i can't seem to locate on Realoem.
Thanks, Rob.
Quote for parts please.
gooner1
- Out humping Reindeer
Cotswoldbmw
Hi Rob
11121726478 Set Bolt Cylinder Head TORX 1 £27.04
Complete Headgasket set for 1986 325I X 1. 11129059240 £239.10
11311713361 x 1 Timing Belt £33.78
11421265376 x 1 Pipe £43.09
11351280551 x 1 Guide £8.03
52101817063 x 2 COUNTERSUNK HEAD SCREW £1.10 for 2
11151714390 X2 O RING £1.75 for 2
07119915031 X4 Hex bolt with washer £0.61 for 4
11141275466 X 1 SHAFT SEAL £20.89
11121285609 X 1 SHAFT SEAL £12.25
11141720903 X 1 GASKET £1.18
11131730234 X 1 GASKET £12.76
11111285403 X 1 O RING £1.98
11241713342 x 12 Piston Rod Bolts £44.84 for 12
11221717840 x 8 Flywheel Hex bolt £10.80 for 8
52101817063 x 2 COUNTERSUNK HEAD SCREW £as above
11251713195 x 6 REPAIR KIT PISTON RINGS 84,480MM(+0,50) £180.54 for 6
Main Bearing Bolts 11111735525 i think they are M10X75 please check size and qty £4.03 each
Prices inc. E30Zone Discount and VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote
11839
There is a P&P cost of £1.99 on all orders under £20
Please remember if you require an urgent response drop our
Parts Department an email
partscheltenham@cotswoldgroup.com
Brett
11839
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
