318 is chain parts
Looking for genuine BMW parts at discounted prices? Try here!
jonesy318
Post Tue Jan 11, 2011 9:51 am
hi there can you price these up please,
upper timing case gaskets set 11141721919
lower timing case gasket set 11141721802
profile gasket 11141247837
cam cover gaskets 11121721876,11121721475 and 3x 11121721476
timing chain 11311247160
front crank seal 11141439570
stat housing gskt 11531721172
guide rail 11311727342
tensioner 11311743187
sealing ring 07119963355
also could you price up sump gaskets, lower and upper,inlet gaskets and crank rear main seal, and finally one last question, will e36 exh manifold be same as e30 m42 manifold?
Many thanks Ian :?
Cotswoldbmw
Post Wed Jan 12, 2011 1:39 pm
Hi Ian
upper timing case gaskets set 11141721919 £5.94
lower timing case gasket set 11141721802 £9.91
profile gasket 11141247837 £4.10
cam cover gaskets 11121721876,£19.01
11121721475 £1.81
3x 11121721476 £4.61 for 3
timing chain 11311247160 £77.18
front crank seal 11141439570 £14.50
stat housing gskt 11531721172 £4.86
guide rail 11311727342 £59.87
tensioner 11311743187 £38.26
sealing ring 07119963355 £0.29
sump gaskets, lower and upper,£26.24 for both
inlet gaskets £15.06 for both
crank rear main seal£34.21
Prices inc. VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 52551
There is a P&P cost of £1.99 on all orders under £20
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
