Can I get a price with availablilty on the below please, sorry for the length of the list
Inner hex bolt M8X22 33311129676 x 8
Collar nut M14X1,5 33331126136 x 4
Plastic washer 10X16X0,9 25111220439 x4
Securing clip 25117571899 x2
O-ring 10X2,2 25111221243 x4
Spacer 16X10,2X0,65 25111220199 x2
Circlip 8,0 07119932863 x2
Torx bolt M12X45 23001222890 x2
Torx bolt M12X75 23001222893 x2
Flat Washer 07119931699 x4
WAVE WASHER B8 07119932095 x4
Torx bolt M10X65-8.8-ZNS3 07129904681 x2
WAVE WASHER B10-ZN 07119932112 x2
Hex nut AM10-8-ZNS3 07129904864 x2
Gasket set 11429059338 x1
Oil pressure switch M12X1,5 12617568480 x1
Charlie
Parts for a bit of a rebuild
charlE30
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
Cotswoldbmw
Hi Charlie
Inner hex bolt M8X22 33311129676 x 8 £9.22 for 8
Collar nut M14X1,5 33331126136 x 4 £4.57 for 4
Plastic washer 10X16X0,9 25111220439 x4 £0.60 for 4
Securing clip 25117571899 x2 £0.76 for 2
O-ring 10X2,2 25111221243 x4 £1.79 for 4
Spacer 16X10,2X0,65 25111220199 x2 £0.62 for 2
Circlip 8,0 07119932863 x2 £0.31 for 2
Torx bolt M12X45 23001222890 x2 £5.97 for 2
Torx bolt M12X75 23001222893 x2 £1.90 for 2
Flat Washer 07119931699 x4 £0.76 for 4
WAVE WASHER B8 07119932095 x4 £0.60 for 4
Torx bolt M10X65-8.8-ZNS3 07129904681 x2 £2.00 for 2
WAVE WASHER B10-ZN 07119932112 x2 £0.31 for 2
Hex nut AM10-8-ZNS3 07129904864 x2 £1.02 for 2
Gasket set 11429059338 x1 £7.57
Oil pressure switch M12X1,5 12617568480 x1 £7.17
Prices inc. VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 50357
There is a P&P cost of £1.99 on all orders under £20
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
charlE30
Cheers Brett,
Can you also give me a price on the following, I'll then give you a ring and place the order
Distrubution Piece M10X1 34341111435 x 1
Pipe M10/M10-380MM 34326755567 x 1
Pipe M10/M10-283MM 34326755328 x 1
Pipe M10/M10-751MM 34326755591 x 1
Pipe M10/M10-3075MM 34326755684 x 1
Do the pipes come ready formed and can you put these on a seperate reference number?
Charlie
Charlie
BMW F31 335d xdrive
BMW F31 335d xdrive
Cotswoldbmw
Hi Charlie
these dont come formed you will need to shape them yourself
Distrubution Piece M10X1 34341111435 x 1 £5.23
Pipe M10/M10-380MM 34326755567 x 1 £4.68
Pipe M10/M10-283MM 34326755328 x 1 £3.75
Pipe M10/M10-751MM 34326755591 x 1 £11.09 for 2
Pipe M10/M10-751MM 34326755591 x 1 SEE ABOVE
Pipe M10/M10-3075MM 34326755684 x 1 £10.89
Please call our Parts Dept. on 01242 257999 and quote 50665
Brett
Brett
Cotswold BMW Parts
01242 335365
01242 335365
