Hi
I need the following items for my 1988 320i auto cabriolet
front brake pads
front wheel bearings
Afm ( car is running rich )
Cash waiting need asap
prices please for these items
gingerrusta
Tay
give euro car parts a ring you shouldn't be paying more than £20 for the pads and anout £35-40 for each bearing, as for the afm, you can adjust the mixture with a 5 or 6mm hex key in the top if you close it all the way down (clockwise) then turn it back about 3 1/2 times it should be about right, 320's are notorious for over fueling so it'll take a bit of fettling to get it right, grab a mate who owns a garage to hook the old girl up to the emmisions machine and twiddle until it brings it into the parameters but turn it the take the hexkey out or you'll get an in accurate reading!!!!
gingerrusta
cheers for that much appreciated .
