Hi Cotswold, I need the following bits & bobs to fit my tech 2 kit.
Front
1 x 51712239711 - Clamp (already have the other 6)
8 x 17111712963 - Expanding rivet
2 x 51711933719 - Clamping bolt
2 x 51711922599 - Clamp
2 x 16131176747 - Plastic nut
Side skirts & door pods
12 x 51712231992 - Clamp
4 x 17111712963 - Expanding rivet
6 x 51161881149 - Expanding rivet
4 x 51711964949 - Clamp
4 x 07119907925 - Fillister head self tapping screw
2 x 51162239883 - clamping bolt
2 x 41335480120 - cap nut
18 x 51162239735 - clamp
18 x 51121867907 - grommet
12 x 51712239736 - lock
2 x 07119916949 - hex head screw
19 x 51711936929 - rivet
Rear
2 x 07119907957 - Fillister head self tapping screw
1 x 51122239847 - Guide left
1 x 51122239848 - Guide right
4 x 51711939303 - grommet
4 x 51711936929 - rivet
EDIT: Can i also have..
2 x 61661373401 - Windscreen spray nozzle
(Suitable for '88 cabby if they're different)
please break it to me gently!
Mtec 2 kit fitting bits
kman82
kman82
..... By the way i put the rough description of the item from Realoem, if it doesn't match up with the part number or is nothing to do with fitting tech 2 could you let me know please. Cheers guys
Tay
i bought all these bits from BMW and they weren't to bad quite cheap if i remember rightly, however with a couple of the clips and bits you do have to buy them in 10's which is a bit of a kick in the teeth!!!! i could probably dig up what spares i have if you need????
kman82
^ That would be really good of you mate, I'd be happy to paypal you their value
I'm still keen for the prices though Cotswold as the car is in the body shop as we speak.
TIA
TIA
Cotswoldbmw
Hi There
1 x 51712239711 - Clamp (already have the other 6) £0.79
8 x 17111712963 - Expanding rivet £1.27 for 8
2 x 51711933719 - Clamping bolt £2.16 for 2
2 x 51711922599 - Clamp £0.60 for 2
2 x 16131176747 - Plastic nut £0.68 for 2
12 x 51712231992 - Clamp £19.80 for 12
4 x 17111712963 - Expanding rivet £0.63 for 4
6 x 51161881149 - Expanding rivet £0.89 for 6
4 x 51711964949 - Clamp PART NUMBER NOT KNOWN
4 x 07119907925 - Fillister head self tapping screw £0.60 FOR 4
2 x 51162239883 - clamping bolt £6.87 FOR 2
2 x 41335480120 - cap nut £0.31 FOR 2
18 x 51162239735 - clamp £20.56 for 18
18 x 51121867907 - grommet £5.33 for 18
12 x 51712239736 - lock £17.26 for12
2 x 07119916949 - hex head screw £0.31 for 2
19 x 51711936929 - rivet £3.02 for 19
Rear
2 x 07119907957 - Fillister head self tapping screw £0.31 for 2
1 x 51122239847 - Guide left £1.08
1 x 51122239848 - Guide right £1.08
4 x 51711939303 - grommet £4.54 for 4
4 x 51711936929 - rivet £0.63 for 4
2 x 61661373401 - Windscreen spray nozzle £20.37 for 2
Prices inc. VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 49342
There is a P&P cost of £1.99 on all orders under £20
Brett
Rear
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
