VIN: EE47994
08 Lock Ring 1 51211854873
4x Bolts that bolt the following to front panel???
13 ENGINE HOOD JOINT 1 41611906239
06 ADJUSTING BAR 1 32421714641
Water hose between throttle body heating element and throttle body and 2x hose clips
12 Intake tube 1 13711727097
04 Rubber boot 1 10/1991 13711734385
only in conjunction with
-- Blind plug 1 10/1991 13541739249
12 OIL PRESSURE SWITCH M12X1,5 1 12617568480
Price and timescale inc delivery please
318is Bits
Cotswoldbmw
Hi There
08 Lock Ring 1 51211854873 £0.47
4x Bolts that bolt the following to front panel??? nothing listed, do you have size of bolt?
13 ENGINE HOOD JOINT 1 41611906239 £121.52
06 ADJUSTING BAR 1 32421714641 £5.39
Water hose between throttle body heating element and throttle body and 2x hose clips Not sure about this all cooling hoses are shown in section 11 if you have a look there you might be able to identify which one you need, its a bit tricky without seeing it
12 Intake tube 1 13711727097 £45.18
04 Rubber boot 1 10/1991 13711734385 £23.04
13541739249 £2.19
12 OIL PRESSURE SWITCH M12X1,5 1 12617568480 £7.17
Prices inc. VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 41889
There is a P&P cost of £1.99 on all orders under £20
Brett
13541739249 £2.19
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
