Anyone give me prices on these?
E30 coupe arial seal and S50 3.0 air flow metre
Cotswoldbmw
Hi There
i will need chassis no. for air flow meter
and the arial seal is a bit tricky, most of the E30s were imported without radios and then had them fitted at dealerships but there is no real way of knowing what was fitted without some sort of cross referance, can you see if there are any numbers on the arial also need to know if its manual or electric
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
M7STN
Hi Brett,
The airflow is for my S50'd E30, will a registration number do?
It's an electric arial on a 1988 F 325i 2 door. I cant see anything on the arial itself.
Thanks,
Stephen
Thanks,
Stephen
Cotswoldbmw
Hi Stephen
reg number will be fine, if the arial is electric there will be a number by the motor if there is not i am going to say its a none genuine so your best bet for that would be a ICE specialist
Cotswold BMW Parts
01242 335365
01242 335365
