Exhaust manifold lambda plugs
Looking for genuine BMW parts at discounted prices? Try here!
stup86
Post Thu May 06, 2010 6:37 pm
Hi guys,
I need the following items from the picture below.
2 x item 12
2 x item 13
They are Lambda plugs and sealing washers for M52 tubular manifolds. Realoem doesn't give a part number.
Stu
Parts needed:
M40/M20 ignition coil with high voltage lead
Cotswoldbmw
Post Fri May 07, 2010 2:12 pm
Hi Stu
I am going to need to email BMW about this as no number listed on our system either, can i get chassis number of vehicle they fit
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
Post Fri May 07, 2010 2:29 pm
If it helps, here is a chassis number for the E36 328i that I raped for the engine etc on my M52 engine conversion. The reg number was N35CWE
WBACD22090AS61919
The above vehicle would have had this manifold fitted (but obviously had lambda sensors rather than plugs fitted)
