M50 sump
Looking for genuine BMW parts at discounted prices? Try here!
bimanut
Post Sat Jan 16, 2010 6:30 pm
How much would i have to expect to pay for a new sump and rellevent oil part bits for M50 conversion into an E30?
Thanks.
Cotswoldbmw
Post Mon Jan 25, 2010 8:48 am
2 sumps listed can i get chassis number
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
bimanut
Post Mon Jan 25, 2010 6:23 pm
I assume you mean the e36 chassis number?
Not sure that its a good idea to put chassis number on public view but its probably been made into a drain cover or sumat by now.
so here goes : WBACB42000FFO1382
Cook318IS
Post Mon Jan 25, 2010 6:24 pm
You won't want an e36 sump if the engine is going into an e30! You will want one from an m50 from an e34.
bimanut
Post Mon Jan 25, 2010 6:48 pm
Cook318IS wrote:You won't want an e36 sump if the engine is going into an e30! You will want one from an m50 from an e34.
That much i know,hence why im asking for price on a new sump on an M50 into E30 conversion :)
Just didnt think that chassis number for the E30 would be of much use :?
Cook318IS
Post Mon Jan 25, 2010 7:41 pm
Neither would a vin from an e36 then if you want an e34 sump. I wanted to make sure that you knew that you needed an e34 sump before you buy a brand new one from the dealers which turns out to be wrong for the conversion.
http://bmwfans.info/parts/catalog/E34/S ... indicator/
This is the part numbers for the sump and that. There are two different ones, like Brett has said for the e36. I don't know the difference though. As far as i knew, the m50 ones were the same. Probably teaching you to suck eggs but make sure you buy a new sump gasket too.
HTH.
bimanut
Post Mon Jan 25, 2010 8:34 pm
All a bit bloody confusing this.
I had a look at the link and that shows two different sumps for the E34 M50 ,before `94 & after `94.
Your right i would be gutted if the sump that turned up was the same one as i`ve already got.
(E36 M50)
The only idea i can think of is if there`s a difference between vanos and non vanos.
Mine being the non vanos.Apart from that i aint got a clue.
Thanks for the input :)
Cook318IS
Post Fri Jan 29, 2010 7:57 am
Well what I can say is that I have a non vanos e34 engine in my e30 and I didn't need to change the sump.
Post Fri Jan 29, 2010 9:42 pm
Either will do, as long as its for an E34 M50 engine it will fit, but not the iX 4WD obviously
