Hi Brett,
Could I please have a quote for the following:-
Headlights (for a complete car set) - sorry, the diagram on RealOEM is rather confusing:-
Aim Adjusters with white ends (complete set, which is 2 or 3 per light unit? - so 4 or 6 in total)
The same number of black plastic sockets that they sit in on the lamp unit
I assume the adjusters come with the black clips that secure them to the plastic frame? If not then the same number of them - my hydraulic adjusters still work if that helps!
2 x headlight bolts and clips (that hold the headlight unit to the car itself)
6 x Spring clips that hold the headlight grills to the body.
Suspension:-
2 x E46 Cabbie rear top mounts
2 x front ARB drop links - Part No. 31351091764
2 x front ARB bushes - Part no. 31351129139
2 x rear ARB drop links - Part No. 33551126932
2 x rear ARB bushes - Part no. 33551130349
Other:-
1 x Front bake pad wear indicator - Part No. 34359058889
2 x Rear brake light cluster seals (1 RHS and 1 LHS)
Car is a 325i touring, 1989 - reg YIL 6039
I will have to place the order with you by tomorrow or Saturday morning if you are open...
many thanks,
Various Suspension and headlight parts
MattCyclone
