Part number request??
Looking for genuine BMW parts at discounted prices? Try here!
GlasgowE30
Post Mon Oct 12, 2009 9:31 pm
Hi Carl,
i have changed the drums, pads, Discs, Pads and went to bleed the system when I found a leak, the leak is above the Diff, I would imagine there is a split point where the main pipe supplying the rear breaks gets diverted.
With this in mind could you advise the part needed to solve this leak??
i cant see anything in the haynes manual regarding this split in the system.
Thanks in advance
Rob. :D
