Hi
could i please have a price for the following
all is for a 89 535i M30b35
timing chain + oil pump chain
timing chain cover gasket
timing chain tensioner + Guides
big end bearings
sump gasket
water pump gasket
crank shaft end cover gasket (if that makes sense its U shaped)
crankshaft rear oil seal
water thermostat
oil pump
part no - 26111206718 (drive shaft stud)
part no - 07119932190 (washer)
part no -11231253339 (nut)
part no - 11 53 1 272 866 (T piece)
cheers
ben
price please M30
Driftben
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
Driftben
And can I add main bearings too
thanks
ben
thanks
ben
6pot wilwoods front
4pot Porsche rear
Driftben
still after a price please
i know your busy as......
6pot wilwoods front
4pot Porsche rear
Driftben
11311716986 timing chain
11311253236 chain guide
11311262273 chain tensioner
07119963355 tensioner gasket
11310731115 tensioner spring
07119986250 Ball
11311744347 pistion
11331744355 bolt x12
11331744354 ECCENTRIC x12
11331258327 washer x12
11331744333 nut x12
11421738621 bolt
11421252343 gasket ring
11341710975 valve collets x12
11141726731 gasket
11141726733 gasket
11141715100 shaft seal
11142249533 shaft seal large
11141250073 gasket
11131315154 gasket
12611277129 gasket
11241284551 bearing shell x6
11241284550 bearing shell x6
11211261033 bearing shell x2
11211261041 bearing shell x12
11421722688 gasket
12617568480 pressure switch
11411705055 tensioner (oil)
11421271320 pistion
11411744324 spring
11411267050 spring seat
07119934619 lock ring
11511265654 gasket
11531713040 thermostat
11531275881 vent screw
26111206718 (drive shaft stud) (E30)
11231253339 (nut)
I HAVE ADDED THESE AS WELL
07129908135 studs x6
11120621144 head bolts x14
11120621145 flat washers x14
there we go i hope that makes it easier
07119986250 Ball
11311744347 pistion
11331744333 nut x12
11421738621 bolt
11141726731 gasket
11141726733 gasket
11141250073 gasket
11131315154 gasket
12611277129 gasket
11421722688 gasket
11421271320 pistion
11411744324 spring
11511265654 gasket
11231253339 (nut)
6pot wilwoods front
4pot Porsche rear
Cotswoldbmw
Hi Ben
i am dealing with this now for you can i get email address
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
Driftben
Lovely cheers Brett
my email is littleoldben@googlemail.com
6pot wilwoods front
4pot Porsche rear
Driftben
Hi brett
i have added the quantity of the items i want if you could review the invoice plus i have added a set of 6 studs and a full set of head bolts to the list.
once the invoice gets amended i can order the whole lot....
im really in need of this lot so i can finish the engine
thanks
ben
thanks
ben
6pot wilwoods front
4pot Porsche rear
Driftben
Bump (without being annoying)
6pot wilwoods front
4pot Porsche rear
Cotswoldbmw
Hi Ben
sorry for delay i have been covering holidays and staff sickness in another dept, but back today and clearing the back log just sending amened estimate
Brett
Brett
Cotswold BMW Parts
01242 335365
01242 335365
Driftben
Ok cheers Brett.
Just in the process of paying now.
6pot wilwoods front
4pot Porsche rear
Driftben
Hi brett
still haven't recieved my box of bits... I was wondering if they deliver on the Saturdays?
Cheers mate
ben
Cheers mate
ben
6pot wilwoods front
4pot Porsche rear
Cotswoldbmw
Hi Ben
have you recived yet? if not let me know and i will chase
Brett
Brett
Cotswold BMW Parts
01242 335365
01242 335365
