for a '86 M20B25 engine. Please give me "rough" quotes for things that need more information please. I'm pricing up my project atm so would like to get an Idea. Let me know though where you need more info.
Clutch
Master/Slave cylinder and all tubings/parts etc
Piston rings (just an estimate)
Rocker cover gasket.
As many Miscelaneous parts for cylinder head (minus the head and head gasket)
Engine mounts
Injectors
spark plugs?
Viscous fan coupling (later (1990) cooling system if it makes a difference)
Thermostat (later (1990) cooling system if it makes a difference)
Blue/Brown ECU leads
Is there a nuts/bolts set for the M20 engine? To redo all those old tatty ones?
+ If theres anything you can think of/or spot that I will need, please advise me on them too!
Thank You!
Lots of 325i parts...please.
Nay
- Channel Island Crew
Uni is killing the project.
madbuck
Edited out by Chris-W
Please do not offer parts in this section of the forum - this is exclusively for requests for new parts from Cotswold BMW.
Cotswoldbmw
Hi There
Clutch £267.31 surchage of £48.60 will come of that price
Master/Slave cylinder and all tubings/parts etc £186.62
Piston rings (just an estimate) £24.08 each
Rocker cover gasket. £12.62
As many Miscelaneous parts for cylinder head (minus the head and head gasket) you will need to let me know exactly what you want
Engine mounts £68.82 for 2
Injectors £567.04 for 6
spark plugs? £32.49 for 6
Viscous fan coupling (later (1990) cooling system if it makes a difference) £152.11
Thermostat (later (1990) cooling system if it makes a difference) £24.31
Blue/Brown ECU leads part of main loom
Is there a nuts/bolts set for the M20 engine? To redo all those old tatty ones? nope all individual
Prices inc. VAT delivered to mainland UK
Please call us on 01242 257999 and quote 50964
There is a P&P cost of £1.99 on all orders under £20
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
