I usually call but seing as there are so many bits I will phone with the reference number please.
Prices of following please. Thanks.
64111375719 x 1
64111370937 x 1
07119920022 x 4
07119912570 x 2
07129946400 x 3
07119932095 x 8
64521284748 x 1
07119936441 x 1
12317677914 x 1
64521284966 x 1
Air con fan belt for a 1990 M20B25 engine. Real OEM lists 2.
64121379221 x 5
12141305028 x 3
07119916973 x 2
07119916970 x 4
16111152613 x 1
07119916965 x 1
07129922705 x 1
64531372613 x 1
07119931044 x 1
07119933082 x 1
17111150170 x 1
64531357128 x 1
07119916842 x 2
All of the little rubber O rings which go between the Air con pipes on a 1990 M20B25 car. Sorry, I can't find their part numbers.
07119916944 x 2
31421236241 x 2
31421236240 x 2
07129901651 x 2
51711825972 x 1
82319067394 x 1
The three little plastic 'screws' which hold on the under dash panel on the drivers side. Please check the part number, as last time you sent the wrong ones (
