Rear Axle Parts
MrWhite
I would like to order the following:
Rear brake protectors OS + NS - 34 21 1 162 061 / 062
Disc locating bolts x4 - 34 11 1 123 072
Fuel vent pipe cover x1 - 16 13 1 179 011
Z3 M Diff Bush x1 - 33 17 2 228 425
Diff case gasket x1 - 33 11 1 210 428
Trailing arm bushes x4 - 33 32 9 061 945
Trailing arm nuts x4 - 07 12 9 900 047
Rear beam bushes x2 - 33 31 1 129 144
Rear ARB drop links x2 - 33 55 1 126 932
Swing support bracket x2 - 33 32 1 127 717
CV joint boot set inner x2 - 33 21 9 067 814
CV joint boot set outer x2 - 33 21 9 067 815
The car is a 1990 318is
Can I please have individual prices and total incl cost for all the above plus a ref number.
rust never sleeps
MrWhite
Can I add these to the list also:
Pulse generator o-ring - 33 11 1 206 166
Pulse generator bracket - 33 11 1 206 076
rust never sleeps
MrWhite
Bump
rust never sleeps
MrWhite
Bump
rust never sleeps
Cotswoldbmw
Morning
Here's the prices
061 £13.52
062 £13.52
072 x4 £2.92
011 £28.06
425 £22.33
428 £1.06
945 x4 £54.03 But you will only need 2 as they come in pairs £27.01
047 x4 £1.23
144 x2 £54.80
932 x2 £22.32
717 x2 £2.33
814 £34.66
815 £30.07
166 £0.36
076 £1.36
All prices include Vat,Discount And Delivery to main land UK
Ref No 44288
If you would like to ask about the above list please call on 01242 257999
Regards Karl
Here's the prices
061 £13.52
062 £13.52
072 x4 £2.92
011 £28.06
425 £22.33
428 £1.06
047 x4 £1.23
144 x2 £54.80
932 x2 £22.32
717 x2 £2.33
814 £34.66
815 £30.07
166 £0.36
076 £1.36
Ref No 44288
Regards Karl
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
MrWhite
All ordered parts received now Karl, thanks.
Can I please have some prices for the following:
34 32 2 283 224 - Brake Pipe OS Front
34 32 6 755 560 - Brake Pipe NS Front
34 32 6 755 686 - Brake Pipe Front - Rear
34 32 6 755 567 - Brake Pipe Rear OS
34 32 6 755 591 - Brake Pipe Rear NS
34 34 1 163 565 - Clip (x4)
34 34 1 111 435 - Distribution Piece
34 40 6 751 588 - Spiral Pin with Spring (x4)
16 12 1 179 681 - Fuel Feed Line
16 23 2 279 682 - Fuel Return Line
16 12 1 115 005 - Clamp (x5)
16 12 1 115 064 - Bracket (x4)
11 12 1 176 766 - Spacer (x3)
16 12 1 180 409 - Fuel Hose (x2)
16 11 1 179 644 - Heat Shield
16 12 1 177 553 - Hose
Thanks..
Thanks..
rust never sleeps
Cotswoldbmw
Afternoon
224 changed to 34.32.2.283.835 £6.35
560 £4.34
686 £9.73
567 £4.34
591 £4.91
565 x4 £2.20
435 £4.60
588 x4 £2.99
681 £14.96
682 £14.96
005/064/766 dont come up what are them meant to be ?
409 x2 £23.41
644 £6.12
553 £19.62
All prices include vat,discount and delivery to mainland uk
Ref No 45125
Regards Karl
560 £4.34
686 £9.73
567 £4.34
591 £4.91
565 x4 £2.20
435 £4.60
588 x4 £2.99
681 £14.96
682 £14.96
409 x2 £23.41
644 £6.12
553 £19.62
Ref No 45125
Regards Karl
Cotswold BMW Parts
01242 335365
01242 335365
MrWhite
Hi,
005/064/766 are the clips and spacers for the fuel and brake hard pipes running under the car.
http://bmwfans.info/parts/catalog/E30/2 ... ing_parts/
Items 4, 5 & 7 on this illustration.
rust never sleeps
Cotswoldbmw
OK
No 4 £0.86
No 5 £0.53
N0 7 £0.59
Regards Karl
Same Ref as above
No 4 £0.86
No 5 £0.53
N0 7 £0.59
Regards Karl
Same Ref as above
Cotswold BMW Parts
01242 335365
01242 335365
MrWhite
Would that be /each for those prices?
rust never sleeps
Cotswoldbmw
Sorry yes thats for each on the above
Cotswold BMW Parts
01242 335365
01242 335365
MrWhite
Thanks.
rust never sleeps
Cotswoldbmw
No Problem
Cotswold BMW Parts
01242 335365
01242 335365
MrWhite
All parts received now. Many thanks.
rust never sleeps
