E34 535i (87/88 ish) airbox parts please
Looking for genuine BMW parts at discounted prices? Try here!
MJJ_ZX6RR
Post Tue Apr 07, 2009 7:08 pm
I need some airbox parts please to fit an OEM airbox back into my E30 M30 engine bay.
Airbox cold air intake - 13711726133
Airbox rubber distance mounting - 13711259818
Rubber boot - airbox to throttle body - 13711707767
Hose clamp - 18111763219
Part numbers according to realoem, let me know if these are no use.
Thanks,
Martin.
Lots of bikes, the odd modern BMW, and now an 88 e30 335i Cab project with E32 running gear
Cotswoldbmw
Post Wed Apr 08, 2009 4:34 pm
Evening
133 £11.68
818 £3.59
767 £15.12
219 £2.85
All prices include vat,discount and delivery to mainland UK
Ref No 43911
Regards Karl
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
MJJ_ZX6RR
Post Tue Apr 21, 2009 2:35 pm
Thanks Karl.
Found out I need a fair few more bits please too, so please add these to the same reference number and i will give you a call to order.
E30 325i Exhaust gasket x2 18301711969
E32 735i M30B35 bits
Valve Cover gasket 11121730231
Radiator (aircon model) 17111723467
Radiator temp sender gasket 07119963244
Oil Cooler pipe (lower) 17221712246
Oil cooler pipe (upper) 17221712245
Oil cooler o-ring x2 17211742635
Oil cooler o-ring x2 17211742636
Oil cooler pipe fixing clamp 17221712573
Thermostat bleed screw 11531275881
I also need the two auxiliary (alternator, PS pump etc) drive belts for the 1988 E32 735i engine, but cannot find these part numbers on realoem.
Cheers,
Martin.
Cotswoldbmw
Post Wed Apr 22, 2009 1:35 pm
Afternoon
969 x2 £15.82
231 £15.32
467 £402.91
244 £0.21
246 £50.85
245 £58.96
635 x2 £0.85
636 x2 £0.85
573 £0.98
881 £1.67
Alt belt £7.15
I will need the chassis so i can get the right p/s belt
Ref No 44972
Regards Karl
Cotswold BMW Parts
01242 335365
MJJ_ZX6RR
Post Wed Apr 22, 2009 2:28 pm
Cotswoldbmw wrote: I will need the chassis so i can get the right p/s belt
Ref No 44972
Regards Karl
Excellent, thanks a lot Karl.
I don't have the chassis no. of the E32, it is long gone after donating its running gear into my E30. It was an 88 E32 735i with aircon, is that enough info?
Martin.
Cotswoldbmw
Post Wed Apr 22, 2009 3:52 pm
Ok the belt will come to £5.07 same ref as above Regards Karl
Cotswold BMW Parts
01242 335365
MJJ_ZX6RR
Post Mon Apr 27, 2009 5:14 pm
Karl,
Last lot of amendments/additions please, and I will call tomorrow to order.
Please remove:
- Exhaust gaskets (18301711969x2 - no longer needed)
- Radiator (17111723467 - too expensive for me).
Please add 1988 E32 735i parts:
- Valve rocker eccentric adjusters x12 (I think p/n - 11331744354)
- Latest version of cam oil spray bar bolts x2 (I think p/n - 11421738621)
- Latest version of cam oil spray bar washers x4 (I think p/n - 11421252343)
Thank you,
Martin.
MJJ_ZX6RR
Post Wed Apr 29, 2009 4:49 pm
Just ordered over the phone, so forget this one thanks.
Cheers, excellent service as per usual.
Martin.
