Could you kindly supply a quote and referance no for this lovely little lot please?
11311716040 x1
11311714988 x1
11311280960 x1
11311267746 x1
11121726244 x1
07119932095 x14
11611713432 x14
11621711954 x12
11121726241 x2
11151714390 x1
11151280937 x1
The bolt for the m20 camshaft gear wheel x1
Engine earth strap x1
32311153993 x1
32311114508 x1
12511714039 x1
11519070759 water pump x1
11511722677 gasket for same x2
07119919939 x6
M20 output bearing that fits inside the back of the crankshaft that the gearbox imput shaft mates with? (need to replace the one that was already in the M50 crank) cant find it on etk...
11331264677 x1 -assume this is the bracket that locks the rocker shafts in position?
13531722040 x1 fuel pres/reg.
13641730767 x7 o-ring.
Parts to freshen up a '91 320i gear linkage?
pair of rear wheel bearings -hubs not needed
Seal kit for both rear calipers
Handbrake cables for 325i
34111123072 x2
34211162061 x1
34211162062 x1
Many thanks and regards,
Chris
(probably forgotton at least 3 things lol!)
