parts req.
gcs325i
please check last post for complete parts list req.
zimmerbimmer1
- BMW Parts Meister
Hi Gaz,
The drive flange £56.71
Wheel Bearing £46.71
Oil Pressure sensor (connection exposed) £8.65
Oil Pressure sensor (connection encased) £6.31
Blue Temp sensor £19.81
Brown Temp Sensor £13.96
Regards
Paul
Regards
Paul
gcs325i
cheers for the reply Paul
i don't need the wheel bearing or drive flange now just the sensors..
Oil Pressure sensor (connection exposed) £8.65- what i'm i looking for here for the difference between these?
also req price for a z3m diff bush? i will call on monday to order once i have figured out what oil sensor i need.
would it be possible to get a price for every thing needed for a cam belt change including water pump for a 320i and a 325i? this will be getting done in future.
edit. Also req parts 8 to 12 on here http://www.realoem.com/bmw/showparts.do ... g=33&fg=10
cherrs gaz
cherrs gaz
Parts for sale - http://www.e30zone.net/modules.php?name ... 45#2733745
zimmerbimmer1
- BMW Parts Meister
with the oil pressure switch it is a case of seein if the connector is exposed or not
gcs325i
right finally put together a complete list of parts.
z3m diff bush £?
parts 9 to 12 on http://www.realoem.com/bmw/showparts.do ... g=33&fg=10
also req towing eye covers for tech 2 front and rear bumpers think the part numbers are 51112239708 & 51122239897
and all parts on http://www.realoem.com/bmw/showparts.do ... g=33&fg=45 except bar (1) and bush (2) as i have these but need a fitting kit.
cheers Gaz
z3m diff bush £?
cheers Gaz
gcs325i
can i get a price for above please
Cotswoldbmw
Morning mate
im sorry on the wait.
ok z3M diff bush is £22.42 inc vat
708-£4.89 inc vat
897-£4.89 inc vat
o-ring for speed sensor in dif is £0.32 inc vat
bolt for the cover will cost £0.21 each inc vat
and on the pic
no 3 x2 £1.72 inc vat
no 4 x2 £.058 inc
no5 x2 £22.17 inc
no6 x2 £0.33 inc
no7 x2 £1.55 inc
n08 + no9 not on your car
no10 x2 £2.29 inc
no11 x2 £0.34 inc
ref no 27435
all prices include vat and postage to main land uk
if you'd like to order please call on 01242 257 999
Cheers Karl
708-£4.89 inc vat
897-£4.89 inc vat
and on the pic
no 4 x2 £.058 inc
no5 x2 £22.17 inc
no6 x2 £0.33 inc
no7 x2 £1.55 inc
no10 x2 £2.29 inc
no11 x2 £0.34 inc
ref no 27435
Cheers Karl
