'88 Tech 1 Restoration Panels
Looking for genuine BMW parts at discounted prices? Try here!
liftoff
Post Wed Aug 20, 2008 1:01 pm
Hi mate,
Any chance you could quote me on the follwing bits and pieces including delivery please? I would be able to order together to save postage if possible:
Both inner (outer edge) arches - Think I have seen these quoted elsewhere here for about £76?
Both outer rear 3/4 repair sections? Are these different to the later Tech 2 with lower arches?
Front floor corner repair sections. Its gone around the throttle pedal and on the passenger side. Are these available?
Also is there a fitting kit available for the Tech 1 side skirts with all clips and screws? If so how much please?
Many thanks
Scott
zimmerbimmer1
BMW Parts Meister
Post Wed Aug 20, 2008 1:32 pm
could you confirm which model you have.
With regards to the floor corner pieces they are not available seperately
liftoff
Post Wed Aug 20, 2008 2:25 pm
Yeah its a 1988 325 Sport Mtech 1, 2 door coupe.
I haven't been able to have a good look as I haven't collected the car yet, but I am assumming the front floor section is available complete, however, I suspect it may be very expensive and for the reasonably small repair needed I may just use sheet steel or try it cut it out of scrapyard car. Any help you can offer would be great.
zimmerbimmer1
BMW Parts Meister
Post Wed Aug 20, 2008 2:47 pm
The floor pan is no longer available so I would suggest repairing it or find a decent scrapyard car as you say.
The Rear qtr panels are different due to the different rear lamps.
For the Side Skirt clips I would budget £30-40 at the very most
liftoff
Post Wed Aug 20, 2008 3:08 pm
I have seen repair sections consisting of around 2 inches of arches all the way around the rear arches, you can just spot weld in and fill as necasarry. Do BMW offer thses repair sections for the rear 3/4 panels? Or are these just pattern items?
