Prices for the folloowing items
Looking for genuine BMW parts at discounted prices? Try here!
frogman
Post Tue Jul 22, 2008 3:34 pm
The following parts are for a 1990 318is M42 engine
1. Upper Timing Case Gasket Set
2. Lower Timing Case Gasket Set
3. Profile Gasket
4. Cam Cover Gaskets (11121721876, 11121721475, and 3 x 1121721476)
5. Timing Chain
6. Crank Front Oil Seal
7. Thermostat Housing Gasket
8. Tensioner Guide Rail
9. Guide Rail
10. Tensioner
11. Sealing Ring
12. Water Pump Gasket
13. Water Pump
14. Thermostat
15. Oil Pump
16. Fuel Pump
17. Oil Filter
18. Air Filter
19. Fuel Filter
20. Spark Plugs
21. HT Leads
Your best prices please, include for delivery to Southern Ireland
zimmerbimmer1
BMW Parts Meister
Post Thu Jul 24, 2008 9:12 am
1. Upper Timing Case Gasket Set £8.06
2. Lower Timing Case Gasket Set £4.83
3. Profile Gasket £3.07
4. Cam Cover Gaskets (11121721876, 11121721475, and 3 x 1121721476) £18.53
5. Timing Chain £58.67
6. Crank Front Oil Seal £10.46
7. Thermostat Housing Gasket £3.54
8. Tensioner Guide Rail £49.50
9. Guide Rail £27.73
10. Tensioner £31.78
11. Sealing Ring £0.16
12. Water Pump Gasket comes with water pump
13. Water Pump £78.01
on return of old water pump £15.59 refunded
14. Thermostat £22.76
15. Oil Pump see this clickyplease let me know which part is required
16. Fuel Pump £204.02
17. Oil Filter £7.33
18. Air Filter £16.24
19. Fuel Filter £20.66
20. Spark Plugs £13.55 for 4
21. HT Leads £151.72 for set
for delivery of parts to ireland I would guestimate approx £50-70
