E30 M3 parts
Looking for genuine BMW parts at discounted prices? Try here!
jetto
Post Mon Jul 21, 2008 6:22 pm
Hi mate,
I pm'd just before you went away so guess you haven't had a chance to check the parts.
Mostly still the same list apart from a few alterations:-
Exhaust bracket (two of 18211315015)
Hex bolt with washer M8X12 (two of 07119913011)
Exhaust bow (one of 18201310509)
Hex bolt M10X32 (one of 07119915189)
Hex nut M10 (one of 18301737774)
Rubber ring for rear exhaust mount (one of 18211712838)
E36 M3 chain tensioner (one of 11311405081) with gasket ring (one of 07119963418)
Door lock repair kit (one of 51219061343)
Double temperature switch (one of 61311378073)
Front brake discs (two of 34112226813) - I believe these are £144 from you
Universal prop joint that connects rear of gearbox to prop (1 of 26117511454)
Propshaft centre support mount (1 of 26121226723)
Right side bumper bracket (1 of 51111940372)
Hex bolt with washer (2 of 07119913802)
Cap (1 of 51121904506)
Hex nut (1 of 51121938110)
Could you give me the prices for each of the above parts including delivery cost?
Thanks,
Oli
jetto
Post Mon Jul 21, 2008 6:24 pm
Its a 1988 2.3 litre M3 if it helps
zimmerbimmer1
BMW Parts Meister
Post Wed Jul 23, 2008 10:35 am
Hi jetto
Exhaust bracket (two of 18211315015) £4.23 for 2
Hex bolt with washer M8X12 (two of 07119913011) £0.42 for 2
Exhaust bow (one of 18201310509) £3.34
Hex bolt M10X32 (one of 07119915189) £0.39
Hex nut M10 (one of 18301737774) £0.85
Rubber ring for rear exhaust mount (one of 18211712838) £2.95
E36 M3 chain tensioner (one of 11311405081) with gasket ring (one of 07119963418) £81.13
Door lock repair kit (one of 51219061343) £15.02
Double temperature switch (one of 61311378073) £22.33
Front brake discs (two of 34112226813) - I believe these are £144 from you correct :D
Universal prop joint that connects rear of gearbox to prop (1 of 26117511454) £67.06
Propshaft centre support mount (1 of 26121226723) £46.35
Right side bumper bracket (1 of 51111940372) £28.00
Hex bolt with washer (2 of 07119913802) NLA
Cap (1 of 51121904506) £0.46
Hex nut (1 of 51121938110) £0.60
Above prices include vat and postage within mainland UK
jetto
Post Wed Jul 23, 2008 11:21 am
Hi mate,
Thanks for the reply. I'd like to order the following from that list please (can you confirm that the E36 M3 chain tensioner is the correct upgrade to use on my car?):-
How do I go about paying? Bank transfer or is it best to call you and do it over the phone?
Cheers,
Oli
zimmerbimmer1
BMW Parts Meister
Post Wed Jul 23, 2008 11:53 am
Hi Oli,
I would suggest calling me on 01242 257999 with your address and card details
quote reference number 19827 when ordering
Regards
Paul
