hi. i am after the following. any help would be greatly appreciated.
parts are for an e30 325i F reg 2 dr
1. cam belt
2. cam belt tensioner
3. water pump
4. fan belt
5. rear brake shoes.
6. 6 x spark plugs
7. ignition leads
8. rear brake pads
9. clutch slave cylinder
10. exhaust fitting kit
11. oil filter
thanks, tom
Parts list.19/07/08
zimmerbimmer1
- BMW Parts Meister
1. cam belt £17.24
2. cam belt tensioner £49.96
3. water pump £82.86
on return of old pump £14.35 refunded
4. fan belt £5.28
5. rear brake shoes(handbrake). £45.91
6. 6 x spark plugs £17.68 (set)
7. ignition leads £165.60
8. rear brake pads £38.34
9. clutch slave cylinder £51.86
10. exhaust fitting kit do you mean the brackets?
11. oil filter £8.53
4. fan belt £5.28
mk2gtitom
thank-you for the reply. prices are more than i expected! haha nevermind. might be able to afford a few parts so i'l be in touch. tom
