gear/ gear ratios
Looking for genuine BMW parts at discounted prices? Try here!
e30cbe
Post Fri Jul 11, 2008 10:01 am
can the 3.35 and 2.03 ratio gears for first and second be purchased separately and put into a 325i g box ? pl indicate cost thanks
zimmerbimmer1
BMW Parts Meister
Post Thu Jul 17, 2008 11:02 am
would you know which gearbox they come from and i will look into it for you
e30cbe
Post Thu Jul 17, 2008 2:15 pm
this is to be used in a e30 325i gbox, trying to see if the first two ratios from an e30 sport g box can be installed into a regular 325i box, thanks
zimmerbimmer1
BMW Parts Meister
Post Thu Jul 17, 2008 2:28 pm
The main input shaft is different so I don't think the gears will fit, it would probably would be a case of trial and error unless someone here has already tried and done it.
