Hi Paul,
Can you let me know if the following are available and their cost please?
I've still got to get in touch with you to order the list of parts you've already given me prices for, but I haven't managed to catch about.
B34.34.1.111.435 DISTRIBUTION PIECE 1
B16.11.1.180.152 RUBBER GROMMET 5
B16.11.1.180.153 SPACER SLEEVE 5
B07.11.9.915.195 HEX BOLT WITH WASHER 4
B46.51.2.333.345 CAGE NUT 1
B07.11.9.922.038 HEX NUT 4
B07.11.9.931.029 FLAT WASHER 4
B16.14.1.152.266 SENDING UNIT 1
B16.12.1.150.391 GASKET RING 1
B16.14.1.179.992 SUCTION DEVICE W.PUMP 1
B16.11.1.744.369 O-RING 1
B16.14.1.179.720 SENDING UNIT 1
Thanks,
Simon
More bits
zimmerbimmer1
- BMW Parts Meister
B34.34.1.111.435 DISTRIBUTION PIECE 1 £4.34
B16.11.1.180.152 RUBBER GROMMET 5 £10.85 for 5
B16.11.1.180.153 SPACER SLEEVE 5 £12.64 for 5
B07.11.9.915.195 HEX BOLT WITH WASHER 4 £1.23 for 4
B46.51.2.333.345 CAGE NUT 1 £0.45
B07.11.9.922.038 HEX NUT 4 £0.52 for 4
B07.11.9.931.029 FLAT WASHER 4 £0.80 f0r 4
B16.14.1.152.266 SENDING UNIT 1 £74.26
B16.12.1.150.391 GASKET RING 1 £2.54
B16.14.1.179.992 SUCTION DEVICE W.PUMP 1 £216.01
B16.11.1.744.369 O-RING 1 £0.95
B16.14.1.179.720 SENDING UNIT 1 £74.26
simonsimoff
Thanks for that. I'll phone again this week and see if I can catch you. Is there anyone else I can give my details to if you're not available?
Also, I thought of two more things for my list that I'd like to check availability for:
52201916156 BRACKET 2
07119915039 HEX BOLT WITH WASHER M6X16-Z1 4
Ideally I'd get 52101937306 too, but the website realoem.com says it's no longer available.
