Hi,
I'm after a number of parts as listed below. I'd be very grateful if you could let me know the prices and availability of these please.
Kind regards,
Simon
Rear Bodywork
WHEELHOUSE OUTER REAR LEFT Quantity 1 from 09/1987 Part No. 41141972591
WHEELHOUSE OUTER REAR RIGHT Quantity 1 from 09/1987 Part No. 41141972592
Rear Axle
KNURLED BOLT Quantity 2 Part No. 51718181460
INNER HEX BOLT M8X22 Quantity 4 Part No. 33311129676
HEX BOLT M12X1,5X90 Quantity 4 Part No. 33321136406
SELF-LOCKING HEX NUT M12X1,5-10-PHR Quantity 4 Part No. 07129900047
PULSE GENERATOR Quantity 2 Part No. 34521155041
CABLE CLAMP D=6MM Quantity 4 Part No. 63121364431
Handbrake
BOWDEN CABLE Quantity 2 Part No. 34411158421
HEX BOLT M8X22 Quantity 4 Part No. 34411121511
SUPPORT Quantity 2 Part No. 34411163978
REPAIR KIT BRAKE SHOE ASBESTOS-FREE Quantity 1 Part No. 34411159467
EXPANDING LOCK Quantity 2 Part No. 34411163709
PIN Quantity 2 Part No. 34411100640
ADJUSTING SCREW Quantity 2 Part No. 34411100550
TENSION SPRING Quantity 2 Part No. 34411102308
TENSION SPRING Quantity 2 Part No. 34411121900
COMPRESSION SPRING Quantity 4 Part No. 34411100122
SPIRAL PIN WITH COMPRESSION SPRING L=28MM Quantity 4 Part No. 34406751588
Fuel Supply
COVER Quantity 1 from 09/1983 Part No. 16131179011
PLASTIC NUT M6 Quantity 6 Part No. 16131176747
FUEL FEED LINE L=1893MM Quantity 1 from 09/1987 Part No.16121179681
FUEL RETURN LINE L=1912MM Quantity 1 from 09/1987 Part No. 16121179682
CLAMP Quantity 6 from 09/1987 Part No. 16121177005
BRACKET Quantity 4 from 09/1987 Part No. 16121155064
SPACER HOLDER Quantity 3 from 09/1987 Part No. 16121176766
Shopping List
zimmerbimmer1
- BMW Parts Meister
Hi There
1 B41.14.1.972.591 WHEELHOUSIN 1 £70.01
2 B41.14.1.972.592 WHEELHOUSIN 1 £70.01
3 B51.71.8.181.460 bolt 2 £5.46
4 B33.31.1.129.676 BOLT 4 £2.00
5 B33.32.1.136.406 BOLT 4 £23.48
6 B07.12.9.900.047 Self-Locking Hex Nut 4 £1.10
7 B34.52.1.155.041 TRANSMITTER 1 £86.19
8 B63.12.1.364.431 PIPE CLAMP 4 £2.00
9 B34.41.1.158.421 BOWDEN CABL 2 £37.11
10 B34.41.1.121.511 BOLT 4 £0.81
11 B34.41.1.163.978 SUPPORT 2 £10.99
12 B34.41.1.159.467 BRAKE SHOE 1 £43.20
13 B34.41.1.163.709 EXPANDER 2 £23.78
14 B34.41.1.100.640 STUD 2 £1.80
15 B34.41.1.100.550 BOLT 2 £27.01
16 B34.41.1.102.308 TENS SPRING 2 £7.50
17 B34.41.1.121.900 TENS SPRING 2 £12.61
18 B34.41.1.100.122 SPRING 4 £1.53
19 B34.40.6.751.588 Tension pin 4 £2.88
20 B16.13.1.179.011 COVER 1 £29.40
21 B16.13.1.176.747 Plastic Nut 6 £1.83
22 B16.12.1.179.681 TUBING 1 £15.60
23 B16.12.1.179.682 PIPE 1 £15.60
24 B16.12.1.177.005 GUIDE 6 £3.03
25 B16.12.1.155.064 HOLDER 4 £3.62
26 B16.12.1.176.766 GUIDE 3 £1.66
all prices are total inc vat
simonsimoff
Thanks a lot for that. I'll order those as soon as I can reach you on your number. I couldn't catch you about today.
I'll leave off number 7 from that list though - the rear brake transmitters - as they seem a bit steep at £86 each so I'm probably better off sourcing some second hand.
One thing I've missed off the list, as I can't find them on RealOEM, is the nuts that hold the heat insulation above the exhaust. The thin metal ones that are like little caps and disintegrate when you remove them from the car. I think I need about a dozen of those.
