Quite a few bits needed
Looking for genuine BMW parts at discounted prices? Try here!
joker
Post Thu May 15, 2008 11:54 pm
Hi
Sorry for the long list of little parts.
Car is 1990 318is (VIN NUM ...EE47394).
Could I have price and time for delivery on the following:
21521154163 Clutch fitting
21521119541 Clutch Res Cap
34111123072 Hex Bolt Rear Disc (2x)
23121205340 Gearbox Oil Seal
23121282394 Gearbox Oil Seal (Is there a lock ring that goes with these?)
23211490120 Diff Pinion Oil Seal Securing Plate
33121214080 Diff Pinion Oil Seal
18129068568 Exhaust Rear Box
18307525639
18211105365
18211712838 (2x)
17111113699 (2x)
33551126932 Rear ARB Links
07119945196
31331133513 Front Bump Stop (2x)
11421709800 Oil Filter Housing Gasket
11421709513 Oil Filter Housing O-Ring
Also...
Rocker Cover Gasket Set
Emblem for Leather Gear Knob - 5 Speed M with three stripes in top left corner.
Door Microswitch
M3 Front Control Arm Rear Bushes
Rear Subframe Bushes
Z3 Diff Bush
Rear Caliper Repair Kit (2x)
Thank you very much for your help.
Ben
zimmerbimmer1
BMW Parts Meister
Post Mon May 19, 2008 10:59 am
[quote="joker"]Hi
Sorry for the Delay.
Please see below for the pricing
21521154163 Clutch fitting £0.46
21521119541 Clutch Res Cap £2.30
34111123072 Hex Bolt Rear Disc (2x) £1.36
23121205340 Gearbox Oil Seal £9.19 with lock ring
23121282394 Gearbox Oil Seal £5.55
23211490120 Diff Pinion Oil Seal Securing Plate £0.73
33121214080 Diff Pinion Oil Seal £14.79
18129068568 Exhaust Rear Box £120.32
18307525639 £11.99
18211105365 £2.50
18211712838 (2x) 5.31 for 2
17111113699 (2x) £4.86 for 2
33551126932 Rear ARB Links £10.58
07119945196 £0.13
31331133513 Front Bump Stop (2x) £21.78 for 2
11421709800 Oil Filter Housing Gasket £1.05
11421709513 Oil Filter Housing O-Ring £1.22
Also...
Rocker Cover Gasket Set £18.53
Emblem for Leather Gear Knob - 5 Speed M with three stripes in top left corner. the only one available now is where the 'M' logo is in the middle of the gear knob with gear pattern around it £3.57
Door Microswitch £3.16
M3 Front Control Arm Rear Bushes £20.00 set
Rear Subframe Bushes £52.39 pair
Z3 Diff Bush £21.34
Rear Caliper Repair Kit (2x) £29.72 pair
:D :D
