can i have a price for the rubber boot 13 71 1 708 800
, breather pipe 13 41 1 718 777 from body to rocker cover and on the right of the body are a couple of pipes. i cant find them on the parts site. can i have the part of pipe from the metal connector on the body up to the plastic connector on the other end and the what ever i need to secure them nice and tight.
and a spring clip for the air filter box 13 71 1 707 044
i think these codes are correct but could you double check pls or if you need more info let me know. once i have prices i will give you a call.
thanks for your help
