Hi Paul
not sure if you got my PM or not so here goes
can you get me a quote for the following please
these are for a faclift 07/1990 325i sport chassis # AE55166
rear exhaust system (to fit mtech kit)
2x black exhaust trims
all hangers/brackets for rear exhaust section
all rear suspension bushes and top mounts including rear sub frame mounts and anti roll bar drop links and rubber bushings
rear diff mounting bush
all front end bushes inc top mounts and new control arms (for ball joints)
e36 m3 offset TCA bushes
front anti roll bar drop links and bushes
new sports suspension front dampers (not entire strut, just the damper insert itself)
is there any other bushes/ball joints etc that you think i have missed or that you could recommend fitting/replacing whist i have these parts apart or is there anything that i have missed that you normally recommend fitting at the same time.
cheers
Chris
Lots of prices
billgatese30
zimmerbimmer1
- BMW Parts Meister
Hi Chris.
I did get your PM but have been busy till now, My Apologies.
Anyway prices are as follows
rear exhaust system (to fit mtech kit) £233.12
2x black exhaust trims £31.20 pair
all hangers/brackets for rear exhaust section £30.89
Rr top mounts std £33.30 pair
Rr top mounts (uprated E46 M3 Cab Mtgs) £33.30 pair
sub frame mounts £52.39 pair
anti roll bar drop links £21.15 pair
anti roll bar rubber bushings £5.68 pair
rear diff mounting bush std £35.30
rear diff mounting bush uprated £21.34 (Z3M)
top mounts £82.03 (pair)
new control arms £92.81 each
e30 m3 offset TCA bushes £20.00
front anti roll bar drop links £54.03 pair
front anti roll bar bushes £13.78 pair
new sports suspension front dampers £92.81 each
I can'y think of anything else you would need to replace unless anybody else can think of anything.
Regards
Paul
Regards
Paul
billgatese30
thats ok, i just thought that with you being busy it may have not got through
can you order me the following please
cheers
Let me know how you would like paying, i can either do an online banking transfer or call you with card details if you prefer.
cheers
zimmerbimmer1
- BMW Parts Meister
Hi,
Please call me on 01242 257999 with your card details
quoting reference number 12438
