Hi I am sure this is the right description for this,
It is the vented diff cover for a large LSD.
I would like a price for this and the diff rubber mount please..
Edit: Also rear anti roill bar bushes and drop links.... thank you
I thank you for your time...
MZ3 Diff Cover.
zimmerbimmer1
- BMW Parts Meister
Diff cover (with bush) £167.40
Rear Anti roll bar links £10.58 each
The bushes i need to know wha model you have due to variation in sizes
bmwscorpion
Thank you.
Is the cover with gasket, bolts etc.
Anti roll bar is an Alpina C2 one I believe to be 325i am I better to measure it before ordering,
I would also like rear E46 Cab top mounts.. Pair please.
I think that is all for the minute..
Alan
Alan
zimmerbimmer1
- BMW Parts Meister
the price is just for the cover
If you could measure the bar i can then quote more accurately
E46 Cab top mtgs £33.30 pair
bmwscorpion
TY
I will measure the roll bar tonight.. Can you also get the gasket bolts and drain plugs, it would be nice to change the job lot.
Alan
Alan
bmwscorpion
Just measured the roll bar. 14mm ...
I need the drop links as well.
On a touring is the rear bottom window seal available seperatly the tailgate is good but the seal is missing..
Thanks again.
Thanks again.
bmwscorpion
Ordered today thank you..
