Red46 skid plates 10% off for January
Traders Section
HackEngineering
Post Wed Jan 13, 2016 12:01 pm
Hi all,
Anyone running even slightly lowered will be all too familiar with sump damage. The sump hangs right in the firing line and has to be protected to avoid damage that can lead to engine failure or at the very least, a nasty mess.
I am the sole UK seller for Red46 Sump Armor. These guys are E30 owners themselves and so have developed this solution, which requires NO WELDING to fit and gives your sump the protection it needs.
The pieces are made from CNC laser cut 11-gauge 304 stainless and so not only looks great, but can take a battering too. They are available in a number of versions to make oil draining easy. M10, M20, M30 swap, M40/42 and 24v swap when using the E34 sump.
These are usually priced at £200 but I have setup a coupon code for 10% off for you E30 Zone members. Simply use the code 'e30zone' when ordering.
Buy here: http://www.hackengineering.co.uk/produc ... our-e30-2/
