WMS Brakes: 4 pot race / trackday brake upgrade kits
Traders Section
keri-WMS
Post Mon Nov 21, 2011 3:41 pm
About time we had a thread here! :D
There are quite a few options, each "kit" includes calipers/brackets+inserts/discs/bolts - pads and line are extra (to see if a kit will fit your wheels open it's PDF, print it out, check the scale....and offer it up to your wheel!).
When comparing WMS and other 4-pot kits it's well worth noting that EBC pads for the WMS calipers are about half the cost for the same size and material as to fit our main competitor's calipers, and that the WMS/Earls lines are a proper "E30 specific fit", where as the lines supplied with one competitor's kits in the UK are "not great" (do a search here on the zone)! Also the WMS-style of CNC brackets with stainless insterts are not found on competing E30 kits and neither are the WMS/E30 1.25" piston sizes.
Here are the WMS E30 kits (each includes calipers/brackets+inserts/bolts etc/discs):
4P025 - 280x22 size kit with best wheel clearance (printable clearance test profile: 280x22 kit PDF ) = (£439.75+vat RRP - 5% E30Zone member discount) = £417.76+vat, PRICE HELD AT 2013 RATE
Image Image Image
4P028 - 298.5x24 size kit, normally for 16"+ wheels (printable clearance test profile: 298.5x24 kit PDF ) = (£490.32+vat RRP - 5% E30Zone member discount) = £465.80+vat
Image Image Image Image
Wheel clearance:
4P025 (280x22, starts at "-2mm" due to thinner flange):
- 15" BBS (FPS and BBS versions)= no spacer needed (but adding 2mm will get the wheels EXACTLY back in the std position)
- 15" BBS (Alu version) = 2mm spacer, only back to std wheel position again though/
- 15" 4x4 (325ix) BBS = Doesn't fit due to different offset
- 16" Alpina replicas (rare!) = Needed a thin spacer
- 16" Alpinas (real) = No spacer I'm told
- 16x7.5j ET25 AC Schnitzer = No spacer I'm told
4P028 (298.5x24):
- 15" BBS (all versions probably, tested on FPS) = DOES FIT...but you will need a 20mm (maybe 22mm) wheel spacer!!
- 16" Hartge = 2mm spacer needed (maybe 3-4mm)
- 16" Hartge split-rim = 1mm spacer needed (so 2mm)
- 16" Alpinas (real) = 6mm spacer needed, but still "VERY tight"
- 16" Lenso's = No spacer I'm told
- 16" Keskin KT-4 = No spacer I'm told
- 16x7.5j ET25 AC Schnitzer = No spacer I'm told, but "tight"
- 16x9J ET15 Borbet B = "doesn't fit"
- 17" Alpina replicas = Fits, no spacers needed.
OPTIONS:
- Grooved discs are offered as a service, and add £40.00+vat/pr. (price lowered)
- EBC Red pads (fast road / "200bhp+") are £38.08+vat/pr
- EBC Yellow pads (fast road / track) are £44.01+vat/pr
- EBC Blue pads (race only) are £45.20+vat/pr
- EBC Orange pads (fast road / track) are £53.24+vat/pr
- Ferodo DS2500 (fast road) = £61.20+vat/set
- Ferodo DS3000 (race) = £62.22+vat/set
- Front Earls WMS-fit braided brake lines = £35.39+vat/pr
- WMS hub-centric 2.0mm G60 (280x22) disc offset-fix spacers = £19.20+vat/pr (these work on Wilwood 280mm kits as well)
- WMS hub-centric 4.0mm G60 (280x22) disc offset PLUS 2MM spacers = £25.82+vat/pr
- Rear discs = £33.15+vat/pr
- Rear EBC Reds = £46.21+vat/set
- Rear Ferodo DS2500s = £81.91+vat/set
- UK shipping = £FREE (if settled by bank transfer, £10+vat if by PayPal, applies to brake kits only)
SPARES:
- Replacement 280x22mm discs are £60.00+vat/pr
- Replacement 298.5x24mm discs are £87.14+vat/pr
We also do these "OEM Fit" bits if it helps:
E30 325i etc (vented front discs, rear discs not drums):
EBC Red front = £POA+vat
EBC Red rear = £POA+vat
EBC Yellow front = £POA+vat
EBC Yellow rear = £POA+vat
EBC Blue front = £POA+vat
EBC Blue rear = £POA+vat
Standard handbrake shoes = £POA+vat
260x22 front discs = £POA+vat/pr
258x10 rear disc/drum combo = £33.15+vat/pr
Earls braided hose kit (4 lines) = £POA+vat
E30 M3:
EBC Blue front = not available for some reason
Earls braided hose kit (6 lines) = £POA+vat
I've been working on bias a bit recently, ONLY as a simplified "brake setup vs brake setup" comparison, not an overall car study - so this ignores everything other than the caliper/pad/disc.
Here are four examples, interesting results I thought!
Standard E30 saloon (not Touring!)
...fitted with 280mm disc / 1.25" piston WMS kit:
...fitted with 298.5mm disc / 1.25" piston WMS kit:
...fitted with 280mm disc / 1.38" piston WMS kit, this is the earlier spec and is still available for people wanting more front bias inside the 15" BBS (due to running semi-slicks for instance):
---- photos ----
Here's the 280x22 4P025 fitting inside the 15" BBS (made for BMW by BBS) and the FPS-BBS (made for BMW by FPS), but the Alu-BBS (made for BMW by Alu) does NEED the 2.0mm spacer as it's tighter behind the spokes:
290mm vented 2-pot retaining the handbrake, one is already in Beta testing:
"Why do WMS use threaded inserts?"
They are about getting the best of both worlds. Aluminium brackets are easily strong enough to take the loads created during braking, but have a few issues:
- Aluminium is a bit soft to have threads in it if the bolt is taken in and out a lot.
- They are also at risk from people fitting extra washers and/or shorter bolts etc resulting in less engagement, or over-torquing, basic human error etc.
Steel/Stainless brackets on the other hand are fine for the threads, but also have issues:
- They are heavy.
- They are also very expensive to machine.
By fitting heavy duty stainless inserts into aluminium you get the lighter bracket, but with the stronger threads! In effect the aluminium "sees" a much larger bolt/thread so it has an easier life. Other things worth noting:
1 - The inserts are 431 or 303 Stainless Steel. 431 is a VERY high grade of steel, in fact its properties and tensile strength are similar to a Grade 12.9 bolt (think ARP rod bolts etc).
2 - The inserts are fixed into the bracket with a grade of Locktite retainer that can withstand high temperatures (the softening/"disassembly temperature" is 250 degrees C) and is fully resistant to motor oil, unleaded petrol, brake fluid and ethanol.
3 - In destruction-testing we tried to pull an M10 bolt/insert out of a bracket by over torquing it. It made it to 80FtLb (twice the 40FtLb suggested for use one the car) before the Grade 12.9 BOLT stretched.
4 - Lastly this is not an untested concept: Wilwood's own USA-market brackets are aluminium with threaded inserts as well.
Brackets before inserts are fitted:
"What's the lowdown on the G60-disc-correction spacers?"
- 2.0mm thick, use to get the offset exactly back to standard when using G60-based 280mm kits.
- 6082 Aluminium, water cut to avoid heat distortion/lumpy edges. Obviously far more accurate than stamped or cast versions...
- Very accurate thickness due to being cut from sheet.
- Hub-centric on the E30 when using the 5mm-flange 280mm disc (Wilwood and WMS).
- Full-contact to spread wheel loads properly (no wasted holes), also allows maximum heat passage from the disc to the wheel for cooling.
* Probably NOT hub-centric on cars with the 260mm disc as they have full-thickness 7.0mm flanges, thereby "covering" the centre of the hub.
If you want custom versions of these (thicker 280mm type, 260mm type, thicker 260mm type etc) please let me know and I'll be happy to quote. There's a price drop at 5pr, but I can do one-off pairs if badly needed for some reason!
Photos showing the advantage over normal wheel spacers:
WMS 2.0mm spacers showing hub-centric location.
"Cast type" 5mm spacers showing lack of hub-centric location!
Here's how the PDF templates work... :cool:
I just took a couple of pics of the 260mm OEM disc-fit (one-off prototype) kit for reference...
steve_k
Post Mon Nov 28, 2011 8:41 pm
i'm looking at getting a set of the 280mm x 22mm discs as i'm in need of a new pair (mot time) & what i would like to know is would i need to use the 2mm spacers as i allready have a set of spacers all round on the car (running caliber vintage 17" wheels) & iirc the spacers are about 10 - 15mm thick.
i only ask as i dont want the front wheels poking out past the wheel arch.
so can anybody help??
keri-WMS
Post Mon Nov 28, 2011 9:27 pm
As long as your spacers don't snag on the (bigger diameter) disc-location part of the hub you'll be fine. I assume you've got G60 discs at the moment?
E30isKing
Post Mon Nov 28, 2011 10:46 pm
How do your callipers compare to Wilwood ones?
Is it possible to ship these without the discs to reduce shipping costs?
What pads do you recommend for the street/odd trackday?
I have stock brakes and will use the BBK on 15'' wheels...would you recommend spacers?
Thanks a lot
steve_k
Post Mon Nov 28, 2011 11:00 pm
The spacers don't rub snag or catch at all. Currently running EBC 284mm x 22mm discs.
Also you have a new PM winkeye
keri-WMS
Post Mon Nov 28, 2011 11:04 pm
The WMS T20 is about the same spec as the Billet Dynalite.
We can indeed ship without discs (280x22 kit), but there's not much point in most cases unless it's outside europe as the G60 discs need machining to fit the E30 meaning it's often cheaper for use to supply everything.
EBC Reds are hard to beat for general good-value from cold, tougher track use or higher power and EBC Yellows, one step upmarket and with better bite would be the Ferodo DS2500.
The 280x22 kit does fit behind most 15" wheels without spacers, the optional 2mm spacers are mainly there due to the G60 having a thinner flange (5mm vs the original 7mm) to correct the geometry.
Hope that helps! :D
keri-WMS
Post Mon Nov 28, 2011 11:05 pm
steve_k wrote:The spacers don't rub snag or catch at all. Currently running EBC 284mm x 22mm discs.
I'll bung you a reply! :cool:
keri-WMS
Post Tue Nov 29, 2011 1:43 am
E30isKing wrote:I have stock brakes and will use the BBK on 15'' wheels...would you recommend spacers?
Thanks a lot
I forgot to say, you can check if your wheels will fit by using our printable PDF templates, see start of this thread.
I also forgot to say, welcome to the 'zone!!! :D
danryan
Post Tue Nov 29, 2011 8:32 pm
i have a 318 touring non abs on 15" bbs wheels. what option of brake up grade do you offer for this? it doesnt matter if its over the top for the power it has, i just would like the best brakes possible (and looks) without changing my wheels! cheers
keri-WMS
Post Thu Dec 01, 2011 2:24 am
danryan wrote:i have a 318 touring non abs on 15" bbs wheels. what option of brake up grade do you offer for this? it doesnt matter if its over the top for the power it has, i just would like the best brakes possible (and looks) without changing my wheels! cheers
That'll be the ever-popular 4P025 (280x22mm).
The info for it is at the top of this page - fire away if you have any questions? :D
keri-WMS
Post Sat Jan 28, 2012 10:46 pm
I've got the rough weight comparison info done:
E30 F OEM inc pads = 8,835g / corner
4P025 inc pads = 8,185g / corner
4P028 inc pads = 9,025g / corner
E30 R OEM inc pads = 8,000g / corner
RB001 inc pads = 7,295g/corner ESTIMATED, TBC
keri-WMS
Post Fri Feb 03, 2012 2:20 pm
Just a note to say we have had a fresh batch of calipers in! :cool:
280mm brackets are running low but there are plenty of 300mm ones.
Syrup
Post Sat Feb 18, 2012 9:46 pm
Hi!
Iam very interested in your offer...can you please recommend me some brakes for my 325i comvertible, I have 17" alpina replicas... I think that bigger is better, but please, recommend me some :-) thanks!
And how is it with rear brakes, I mean the powers between them, isnt the front too much powerfull against the back?..
keri-WMS
Post Sun Feb 19, 2012 3:06 am
PM sent - the front > rear bias stuff is shown in the first post. :)
phi1
Post Mon Feb 20, 2012 5:53 pm
Hi there, I am building a e30 v8,
Can you give me a price as the following,
280mm kit,
groved discs
red stuff (this the best for track?)
braided lines
298mm kit
groved discs
braided lines
300mm kit
groved discs
braided lines
So 3 seperate prices? I am ready to order tonight so would be great if you can get back to me asap, Will 16's fit with a 300mm kit?
Whats the best for track/drift use?
Also worth mentioning I am using a e34 540 hydro servo and have a bias valve fitted to the car.
keri-WMS
Post Mon Feb 20, 2012 5:55 pm
Hi, sure - I'll get back to you today by PM, give me a little while to work out your prices! :D
phi1
Post Mon Feb 20, 2012 6:08 pm
Brilliant! Be sure to advise me best on the brake pads? also is it worth having groved discs?
keri-WMS
Post Mon Feb 20, 2012 6:12 pm
Will do! I would have EBC Yellows and no grooves personaly....maybe upgrading to the DS2500 or DS3000 as they might have the edge over EBC but with a bit more cost.
phi1
Post Tue Feb 21, 2012 6:03 pm
Sent you a pm back, why wouldn't you use grooves?
Cheers phil
keri-WMS
Post Tue Feb 21, 2012 8:01 pm
I personaly wouldn't use grooves as there isn't normally a need with modern pads - but I know they look good so it's a personal preference thing!
Syrup
Post Wed Feb 22, 2012 9:25 am
Keri you have PM ... I would like to order the set you made, but I just want to ask about a few questions... thanks!
keri-WMS
Post Wed Feb 22, 2012 1:48 pm
Syrup wrote:Keri you have PM ... I would like to order the set you made, but I just want to ask about a few questions... thanks!
So you did, sorry I missed it! I'll reply now.
Thanks for this photo of the 4P028 kit in the 17" Alpina replica, very useful to know it fits and I've updated my wheel list! :thumb:
Syrup wrote:Image
keri-WMS
Post Fri Mar 09, 2012 5:56 pm
Some eye candy for the 298.5x24 4P028 kit: :cool:
In a 16" Hartge split-rim...
...and in grooved form, with grooved OEM-size rears as well...
keri-WMS
Post Wed Mar 14, 2012 6:34 pm
Another mini update - all our hoses are now clear plastic covered on top of the steel braid for added protection.
rix313
Post Thu Mar 15, 2012 9:46 pm
Nice :thumb:
Do you still do the 2 piece bell and rotor disc option? If so what are the prices for 280mm?
keri-WMS
Post Thu Mar 15, 2012 11:03 pm
Just one set left, 280x20.5 rotors on bells:
£321.00+vat outright, or add £154.20+vat as an upgrade to the 4P025 kit.
rix313
Post Sat Mar 17, 2012 10:14 am
Got any pictures?
keri-WMS
Post Wed Mar 21, 2012 1:59 am
Here you go! They are Wilwood ones as far as I know, not our own design. Ignore the bit about listings, that's where I used the photos on eBay.
e30max
Post Wed Mar 21, 2012 9:35 pm
PM'd :)
kam325itouring
Post Sun Apr 29, 2012 3:36 pm
hi
how much would it cost for a set of
300mm kit
ferodo ds2500
braided hoses
cheers kam
All Car Audio - Approved Alarms - HID Kits - Custom Boot Installs - All jobs considered
kam325itouring
Post Sun Apr 29, 2012 3:41 pm
oh will they fit behind lensos 7.5x17" et20 without spacers
keri-WMS
Post Sun Apr 29, 2012 8:30 pm
kam325itouring wrote:hi
300mm kit
ferodo ds2500
braided hoses
cheers kam
Hi Kam, do you mean the 4P028 298.5mm one? We're more or less discontinuing the 300mm one as it's heavier with less wheel clearance and as a result less popular.
So we've had a big batch of the 4P028 298.5mm discs made, but no 300mm.
Let me know and I'll PM you a quote.
kam325itouring wrote:oh will they fit behind lensos 7.5x17" et20 without spacers
I have been told the 4P028 one does fit, but that's third hand.
Best way to check is use the PDF template for the 4P028 kit (see start of this thread), if you have trouble getting it printed at 1:1 let me know and I'll send you one in the post.
Fire away if you have any more questions?
kam325itouring
Post Sun Apr 29, 2012 9:33 pm
Yeap if the 298.5s are better and lighter i would prefer to go for these..
if you can quote me happy pls!!! :D
keri-WMS
Post Mon May 07, 2012 2:08 am
PM sent - bit slow, sorry (got distracted by the VAT return)!
kam325itouring
Post Tue May 08, 2012 9:14 pm
Keri you got a pm!!
