380 & 440cc Injectors for Forced Induction Conversions
Traders Section
Locked
Injectortune
Wed Jun 02, 2010 2:43 am
We have had 380cc & 440cc injectors made to our own specification specifically for tuning turbo/supercharged/throttle bodied engines which require more fuel.
They are the Bosch 0280150xxx style and are physically compatible with all E30 injector types. They are presently furnished with a 'traditional' pintle cap but more suitable BMW style ones can be fitted upon request.
Each new fuel injector comes with an exact flow rate for precise ECU mapping and has been made to the following specification:
380cc or 440cc (36lb/42lb hour) flow rate at 3bar (within 10%).”Ž
16.5ohms (high impedance).
Bosch EV1 connector.
Standard 14mm o-ring diameter.
Standard 65mm o-ring to o-ring length.
Stable in performance up to 5 bar, giving a maximum 490/570cc flow rate.
4-hole pintle with fine, conical spray pattern for maximum power.
Lifetime warranty (replacement).
Awesome green & black finish!
Please feel free to email us your questions and requirements.
Just £45 per injector including UK postage.
Note to mods - Please sticky this thread, thanks!
James.
Ant
Retired Team Member
Retired Team Member
Wed Jun 02, 2010 9:23 am
Done
Mmmmmm Lime green, my fave :D
cecotto_singh
Fri Aug 06, 2010 8:32 am
U got for anything for cosworth yb engines? Siemens or similar.
Johnny_324td
Sun Sep 25, 2011 7:19 pm
I'm looking for 550cc injectors for my M50B25, I'm going to make a turbo conversion...do you have these? the other problem is that I'm in other country, in Portugal... PM me :D
Injectortune
Wed Jan 25, 2012 1:38 pm
We now stock several types of injectors.
Our online shop can be found here
Driftben
Sat Aug 03, 2013 8:41 am
do you have any injectors for a M60b40 that im twin turboing?
would 440cc be suffice for this?
thanks
ben
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
Driftben
Sat Aug 03, 2013 8:42 am
thanks
ben
6pot wilwoods front
4pot Porsche rear
daboy3000
Thu Aug 13, 2015 2:21 pm
Hi. Need a quote for cleaning 318i 1993 injectors.
Also do you know that your website says you are away till 25th July and now we are in August, also the link you posted above is broken, you need to remove url at the end.
Please get inn touch, thanks
daboy3000
Sat Aug 22, 2015 1:49 pm
Or don't then. I will go somewhere else.
Sat Aug 22, 2015 2:02 pm
daboy3000 wrote:Or don't then. I will go somewhere else.
Good luck with that, you won't get a better price, I've phoned several other companies and they charge about £30 per injector :mad:
Have you tried the website? http://www.injectortune.co.uk/Contact.html
Sambino
Mon May 22, 2017 5:31 pm
Hi mate sent e-mail to your website- please contact or drop me pm
Many thanks
Locked
