o2 sensor wiring (m50)
keggy
hey can anyone tell me what each wire is for on no1 o2 sensor on an m50 vanos 525 '95
No 1 sensor? M50 engines only have one sensor. (every one ive seen has anyway)
M52 engines have two, one in each manifold
Depends which part of the wiring you are looking at also as the colours usually change through connectors
Andy325i
Where in the manifolds are they Dan? near the head or down by the front pipe?
keggy
any1????????????
keggy
its teh ones on the actual sensor
What sensor though mate? Standard M50 sensor, the black is the signal wire and the two white are for the heater, grey is earth I think
M52 sensors are down by the frontpipe joints
keggy
cheers mate
just wot i needed. now i have to go out at 5am to go fix it so i can get down to pro drift
