So my plan is to plane and polish the head and fit new rockers and valve springs + a new chip to the Ecu
Are there other things I need to do as well?
The Cam is only for sport, its not a race cam!pacerpete wrote:On a big heavy turd like a 735 , especially an auto a 'lairy' cam will often do little except give you a crap idle, heavier fuel consumption and move your power band up the rev range. Effectively making the car slower at lower speeds and in normal driving !
It can be re-mapped...... they use a map-able chip in place of the original (like a writing to a blank chip), and make adjustments while the car is on a dyno78dude wrote:I will keep the exhaust manifoild standard, I need all the torque as possible because its an 1800 kg car!
To remap the ecu is unpossible because its to old....
