hi i have a e46 bmw and the clock is showing that it needs a service i know there is a way of resetting this if you mess about with the ignition and the buttons on the speedo however forgot the combination... was wondering if anyone knew how to do it#??????
thanks.
e46 service indicator reset does anyone know how???
Yaninnya
I'll check it tomorrow in the workshop. Normally I'm just using GT1.
Jan
Jan
jamsieboi
To reset the indicator:
-The car should be off
-hold down the left instrument button (the trip odometer reset)
-while holding the key, turn the ignition to position 1 (radio)
-you will see a test menu
-keep holding the button
-after maybe 10 seconds, the word "reset" will appear
-let go of the button and press again
-THe indicator is reset!
Think this is pretty much it, don't think it works on early e46's think the cut off is mid 2000
badboy007
nice one thanks for the mine are both 2001 and above so i think i should be ok. cheers pal.
SamiS
- Formerly illmonkey
Any idea about the airbag light reset? Ours is on, think it might be wiring, so i need to fix the wiring, then reset the light to test...
badboy007
the only way as far as i am aware of gettin the air bag light off is by putting it on a diagnostics computerwhich should cost £35 tops, if you are anywhere in sheffield i know a guy that can do it for £25.
hope that helps
hope that helps
SamiS
Thanks. Not near sheffield.
A garage close by will do it for me for free. But its annoying trying to fix as i have to drive it over to get it reset before trying the next thing...
Yaninnya
So here it is:Yaninnya wrote:I'll check it tomorrow in the workshop. Normally I'm just using GT1.![]()
Jan
Distance-based inspection
Switch ignition off
Press and hold button A (the button between spedo and fuel gauge)
Turn ignition key to position I
After 5 seconds the words "OIL SERVICE" or "INSPECTION" are shown together with the message "reset" or "re"
Release button A. Press and hold button A. After futher 5 seconds the message "reset" starts to flash.
Release button A. Press and release button A again.
The new service interval is now displayed.
Press and release button A. The message "END SIA" is now displayed.
Switch ignition off.
Time-based inspection - in conjuction with a distance-based service
Switch ignition off
Press and hold button A for 5 seconds. The time-based inspection is now displayed together with the message "reset" or "re".
I hope it helps.
Jan
