MMMM nice rear end
Onz
Post Sun Nov 25, 2007 2:11 am
What parts do the compacts share with the E30? I heard the whole rear end setup is the same. Is this true? And can you get one with an is lump?
fozzymandeus
Post Sun Nov 25, 2007 8:28 am
The 318ti E36 has the M42/M44 depending on age.
darkchild
Post Sun Nov 25, 2007 10:32 am
The compact came with the 8v M43, 16v M42/M44 and there was also a Euro only 323ti.
Onz
Post Mon Nov 26, 2007 12:09 am
What abou the diff and rear axle?
HairyScreech
Post Mon Nov 26, 2007 12:29 am
i beleive its the same. theres a 318ti in the scrapper near me if you want bits from one.
Onz
Post Mon Nov 26, 2007 12:38 am
i just wanted to know what the rear end setup was like really? Diff size, suspension, bushes, stud pattern etc...
johnono
Post Mon Nov 26, 2007 12:40 am
the e36 / 5 has a very similar rear axle-subframe,
but in fact, shares almost 0 peices with íts predecessor
the diff is usable from an e30 on a comp, but the driveshaft / shaft flanches need to be changed a little
The rear subframe bushes are the same, but dont share the same number, neither does the rear susp. assembly.
the box and m42 will fit over i beleive
the front susp. struts will swap over to a 30
the rear arb wont go
gear shifer from a z3 1.9
The Z3 has a few E30 compatible parts also , as its basically an E36 compact chassis.
Onz
Post Mon Dec 03, 2007 10:14 am
WOW thanks johnono you are the MAN! Any idea about the weight distribution of the comp?
