E36 OBC Retrofit.......
kam-325i
Post Mon Nov 05, 2007 10:47 pm
Any have any info on this job......?
I have had a quick mouch around e36coupe.com......but the info is hard to come by.....
I will be going from the full analog clock...
Its in a 325TD
fozzymandeus
Post Wed Nov 07, 2007 3:12 am
I'm not sure it's possible.
OBC is one layer above check control, for which you'd need to install a lot of sensor equipment, including changing all the light clusters, although I'm prepared to be told otherwise I don't think it's worth doing.
eko
Old timer
Post Wed Nov 07, 2007 10:05 pm
Here you go mate :)
LINK
kam-325i
Post Thu Nov 08, 2007 8:22 pm
cheers
beefy
Post Fri Nov 23, 2007 8:45 pm
any info to fit an obc in a e36 328i sport from a digital clock with check control?
E30 M30 Mounts £100 pm me for info.
